How to hardwire a 12V device to the interior fuse box?
Old Nov 26, 2012
CivicN3wb's Avatar
CivicN3wb is an unknown quantity at this point
Question How to hardwire a 12V device to the interior fuse box?
I purchased a dash cam and need to hardware it to my 2002 Civic EX. It came with a Power Magic box that will disable the camera if the battery voltage drops to low, and the box has three wires coming out of it:
1. ACC (+)
2. BATT (+)
3. GND
If my understanding is correct, then the ACC wire should connect to a pin that is only on when the vehicle is not turned off, the BATT wire should be connected to a pin that is always on (even when the vehicle is off), and GND should connect to a ground pin.
Can I connect these to someplace in the interior fuse box?
Thanks for your help!
Old Nov 26, 2012
GolNat's Avatar
Prelude Owner
Re: How to hardwire a 12V device to the interior fuse box?
Yes you are correct. You can connect the ACC wire to the ignition harness so that when the key is turned to position 2 it will turn on (like the radio). The BATT I would run to exterior fuse box or straight to the battery +. Ground you can attach to the chassis (bare metal) somewhere.
Old Nov 26, 2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
I would just add them to the interior fuse box. No need to run under the hood. There are several ways to add connections to the interior box. Just do a search for car fuse tap. There are ones that wrap around the tip of the fuse and the one I like actually slides over the leg of the fuse. Both provide a tab to slide a connector over. Then just ground the last wire to the chassis somewhere.
roverben
Jan 21, 2019 05:16 PM
wankers
Jan 20, 2019 06:44 PM
Mike Garvey
Jun 7, 2015 07:25 PM
MiniMi
May 27, 2015 01:57 PM
smmahan
Apr 15, 2015 08:17 PM
