Engine light/other issues
Old Nov 18, 2012
henrydariusgibb's Avatar
Noob
henrydariusgibb is an unknown quantity at this point
The other day my check engine light started flashing when I turned my car on. It just flashes for a few seconds and then goes away. I bought an OBD reader and upon hooking it up it can't read anything wrong. I've reset the ecu by disconnecting the battery and by using the OBD reader as well. What's the best way to check the ecu and OBD reader port in the car?
Also when putting the car in park it makes a weird sound. It also does this when in reverse. Any ideas?
Old Nov 18, 2012
chozobody's Avatar
chozobody is an unknown quantity at this point
Re: Engine light/other issues
Possible troll? Is this your first car Henry?
Old Nov 18, 2012
Noob
No man I'm not trolling. I can change the oil and tires.
Old Nov 18, 2012
chozobody's Avatar
Ok, well the blinking engine light is normal. Every Honda I have ever owned flashes it for a few seconds during startup. What sort of sound does the car make when going into park?
Old Nov 18, 2012
Noob
Its sort of like a clunking sound. It does it in reverse as well.
Old Nov 18, 2012
chozobody's Avatar
Thats normal as well. Nothing to worry about.
Old Nov 18, 2012
Noob
Blinking maintenance required light is what I meant to say.
Old Nov 18, 2012
Noob
What? That's not normal. It vibrates the whole car. It started off as off and on. Now, its a pretty regular occurrence.
Old Nov 18, 2012
chozobody's Avatar
You didnt say it shook the whole car. If the maintenance required light stays off, your fine.
Old Nov 18, 2012
https://www.civicforums.com/forums/3...ml#post4624274
The reset is in your owners manual too.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
crowtoo
May 11, 2015 06:50 PM
McD
Apr 29, 2015 03:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
