MPG issues and Maint. required check light ?
Old Nov 16, 2012
laithmajed91's Avatar
laithmajed91 is an unknown quantity at this point
hello all ! i have a 2005 honda civic EX sedan , during last week my MPG dropped from 30 to 23 i drive around 120 miles a day so thats a kick in the nuts :/
my exhaust manifold has been leaking , and i ordered a new O2 Sensor . is there anything else available to cure my mileage problem ? thats what i got after lurking through the forums.
and a month ago my "maint. required" light came on , what should i do to turn it off ?
thanks a lot and i did search through the forums hope u guys could help me out
Old Nov 16, 2012
GolNat's Avatar
Prelude Owner
Re: MPG issues and Maint. required check light ?
A bad O2 sensor can give you bad mpg. Did you order a Honda sensor? Has it had plugs lately? Air filter clean? Tire pressure good? Get exhaust leak fixed.
To reset the maintance light you have to hold the trip button down while you turn the key to position 2. Wait 10 seconds and the light will reset. I think it flashes when it resets.
Old Nov 16, 2012
tires pressure and air filter are good , my sparks are 20,000 miles old i ll change them tomorrow and fix the exhaust this week thanks a lot anything else i should look for ?
Old Nov 16, 2012
and thanks a lot the light thing worked
Old Nov 16, 2012
The correct plugs are good for an easy 100,000+ miles (as long as nothing fouls them).
A cracked exhaust manifold leaking exhaust can cause false readings from the O2 sensor, and the computer tries to add extra fuel to compensate.
Winter blend fuel can cause a drop too.
More:
http://blog.gasbuddy.com/posts/Winte...22955-413.aspx
http://www.metrompg.com/posts/winter-mpg.htm
Old Nov 18, 2012
04 Honda Civic's Avatar
Put the right parts, use the correct OEM plugs and check your air filter.
You need to fix your problems, of course your mpgs will drop with the problems you stated.
Old Nov 19, 2012
thanks a lot guys everything is properly fixed except the manifold , amd already returning 25 MPG
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dooner24
Apr 14, 2015 07:51 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
