Weird stuttering problem 2001 Honda ex
The problem that I am having is not occurring all the time, but it does happen often enough to annoy and get my attention. Here is what happens :I start the car, and everything is fine, no lights no problems
Then I have to shift into either reverse or drive to get out of my parking spot, and this is where the problem happens
I press on the gas to get moving and sometimes the engine stutters. i look down at the dash and the rotations are almost at zero, so i let off the gas and this continues for a few seconds, the rotations then fly up to 2,000 and then back to normal idling (700-500 rpms) and only then can i actually move my car. Can anyone tell me whats going on?
Re: Weird stuttering problem 2001 Honda ex
if you step on the gas and it just revs in drive its most likely a bad transmission. the 2001 model is notorious for failing automatic transmissions some don't last 50,000 miles. otherwise try cleaning your IACV and throttle body see if that helps at all https://www.civicforums.com/forums/1...e-up-mods.html
whens the last time you hade a tune up ???
Lowlife: his engine isn't revving up, it is dying.
I'd probably start with watching fuel pressure while this event is happening, just to get an idea of what might be causing it to stumble. Then troubleshoot, depending on what I see.
Don't scare me with that information man my baby's got 168000+ and i want her to last forever
I am actually getting a tune up this weekend, so hopefully ill find the problem then. thanks for the help lowlife
, ill let you know if I do figure out what it is
LionSpratt
Jan 29, 2017 11:07 PM
bahena08
Apr 11, 2015 05:09 PM
Bartkat
20
Feb 19, 2002 01:29 PM
