Compression drop after timing belt change
Old Sep 1, 2012
emicha's Avatar
emicha is an unknown quantity at this point
Compression drop from 230 to 180 psi after timing belt change.
Timing looks OK
The car drives great. what could be the reason?
Old Sep 1, 2012
mikey1's Avatar
Re: Compression drop after timing belt change
i would be willing to bet money your timing belt is off by one tooth
Old Sep 3, 2012
emicha's Avatar
The car wouldn't start with timing belt off
Old Sep 3, 2012
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
180psi is good, as long as its consistent through all 4 cylinders I wouldn't worry.
The first compression test could have been done wrong or a bad gauge, I don't recall ever hearing any compression tests over 190psi on these motors.
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
slynger
18
May 8, 2015 06:06 PM
Supramk3
May 8, 2015 11:16 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
