Sponsored by:
Sponsored by: DashLynx
Is draining and refilling our coolant as easy as it looks?
Old 06-27-2012
I am Epic
Civicnoobie's Avatar
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
The only thing i know how to do is change my air filter and my ATF. Seeing the DIY on doing a coolant drain and fill (not flush since i dont trust myself putting water in), it looks like something thats not much harder than a ATF drain and fill?
The last time my coolant was changed was 1.5yrs ago. Was just a drain and fill. And had a flush 2yrs ago, but dont recall the mech putting distilled water in, but he did get pretty much all the coolant out of the system.
I know a drain and fill only gets out about 35% of the coolant but if i can do this every year, it would save me from having to pay for a flush. I would just deal with this one cap circled in the pic, drain into pan and refil from top.
Civicnoobie is offline
Old 06-27-2012
Re: Is draining and refilling our coolant as easy as it looks?
You got it, kid.
Open the drain, let it go into a bucket.
Take the cap off of the radiator.
Walk away for 20 minutes while it drains.
Tighten the drainplug, refill the radiator and burp the air out of it. Fill the reservoir bottle to the max line. Check it again after a couple of days.
Takes about a gallon.
That's about half the system capacity.
Factory coolant (Honda Type 2) is blue, long life, non-silicate, non-borate, and is already pre-mixed with deionized water. Just open the jug and pour it in.
ezone is offline
Old 06-27-2012
scooty's Avatar
scooty is on a distinguished road
Is there a coolant drain plug or bolt on the engine block as well?
scooty is offline
Old 06-27-2012
04 Honda Civic's Avatar
Yes there is, not much will come out but if you want to remove it all it will need to be removed.
Put the heat on hot when it drains and open the rad cap makes draining more efficient.
Most important part is getting out all the air or you will overheat.
You know you got it right when your heat is very hot.
04 Honda Civic is offline
Old 06-27-2012
sl33pyriceboi's Avatar
No there isn't. The drain plug is under the radiator.
sl33pyriceboi is offline
Old 06-27-2012
I am Epic
Originally Posted by ezone
You got it, kid.
How do you get the air out? Should the engine and rad be cold when doing this?
Is there anywhere online i can buy honda coolant for cheaper? Cause a 5L is $25 at the dealer.
Old 06-28-2012
^you park on a slope, front facing up and run your engine for 10mins ish.
Old 06-28-2012
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I would point out that if you are using Honda coolant it is long life and replacing it yearly as you originally stated is overkill.
pjb3 is offline
Old 06-28-2012
I am Epic
WITH the radiator already filled to max line with coolant right?
Old 06-28-2012
^yes.
mcollins
Electrical
07-27-2015 10:59 PM
Q-Bert
07-19-2015 09:09 PM
Kyles24
07-16-2015 10:14 PM
Kyles24
07-12-2015 09:15 PM
Bill in San Jos
07-10-2015 12:32 PM
Quick Reply: Is draining and refilling our coolant as easy as it looks?
