Turbo help
Old Jun 23, 2012
HbrandNinja's Avatar
HbrandNinja will become famous soon enough
Turbo help
So i just got my 03 civic ex back from the dyno shop after adding my TSI turbo kit with the AEM FIC and getting it dyno tuned, and i'm pretty upset with the halfassed tune they did. For some reason every once in a while when im driving it around it starts acting like its boggin down and about to die jerking violently the more you presss the gass. Then all the sudden it goes away and wont do it again for the rest of the day or sometimes it will but its just random and its rare but i'm pretty sure that **** aint normal if it happens at all. The guy from the shop said that my wastegate lets boost creep all the way to 10.5 psi at some rpm points even though its set to 7psi, so i was thinking it probably is caused by the boost creeping over 10 and trips out the map? Sorry for the paragraph but i just wanna have this build done right.
Old Jun 25, 2012
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Re: Turbo help
Well I believe your waste gate is controlled by a spring so replace that and see what happens. If its not mechanical, and if it's an electrical problem, that's more of a hassle
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
