Fuel Injector constant stream
Old May 11, 2012
raymann01's Avatar
raymann01 is an unknown quantity at this point
We have a 2005 Honda Civic.. When we turn the key on, the number 2 injector immediately streams/spray's gas. We exchanged injectors, moved wires around, long story short, no matter which injector the number 2 connector is plugged into, it immediately squirts gas as soon as the key is turned on, and doesn't stop... Any help would be appreciated.
Old May 11, 2012
Re: Fuel Injector constant stream
A test light and a wiring diagram, and a little testing should......nevermind.
Disconnect the #2 injector wire (only) from the PCM connector and try it.
If it continues squirting, the problem most likely related to the wiring somewhere between the PCM and the engine.
If that gets it to stop, then the problem should be inside the PCM.
HTH
Old May 11, 2012
raymann01's Avatar
That makes sense, but I'm about as useful as a rock.. Where will the PCM be and will it be obvious which one to disconnect??
HTH
Old May 11, 2012
No, there is no label. No exit ramp, no signs. You must use wire colors and terminal positions, because there can easily be more than one wire of the same color. You have 4 dozen possible color combos and some 7 dozen wires. There will be some duplicates.
You have to pick the single correct wire for the #2 injector out of 90 or so in the PCM harnesses. This is one place where the wiring diagram can be extremely useful.
Old May 11, 2012
raymann01's Avatar
wow.. Well, I will have to get the diagram and hopefully figure that out.. Thanks. for the info
SimpleUser
Apr 24, 2021 02:54 AM
GritzNGravy
Aug 19, 2015 03:03 AM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
jody501
Jul 10, 2015 11:01 AM
