Brake Lighs stays ON - Honda Civic 2001 LX
Old Mar 5, 2012
jdawgzcivic's Avatar
jdawgzcivic is an unknown quantity at this point
Hello,
I have a Honda Civic 2001 LX and the brake lights stays ON without the car running. When I unplug the connection from the brake, the lights turns OFF.
When I plug it back in, stays ON...
What could it be? I'm afraid to bring it to the "stealership" and get "rob"...
I appreciate any help and feedback..
Thanks!
Old Mar 5, 2012
CraigW's Avatar
Re: Brake Lighs stays ON - Honda Civic 2001 LX
There is a hole in the brake pedal arm that has a plastic plug/pin inside where the pedal arm meets the brake switch actuator... if the plastic pin comes out the it allows the switch to stay on. Look at it closely, and lightly work the brake pedal by hand and you should be able to diagnose.
Like this--> https://www.civicforums.com/forums/1...ht-switch.html
Old Mar 5, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
The brake light on the dash? or your taillights?
What connection? The one on the pedal? be a little more specific please
Old Mar 5, 2012
BlueEM2's Avatar
Whachya lookin at?
Possibly the ground on the ebrake. Trace it and see if its connected properly and that there are no breaks in the wire.
Old Mar 5, 2012
There was like a "white plastic" that fell when I opened up underneath... The brake lights and the light in the middle stays on. Also, when the car is running, the brake lights don't work... Thanks!
Old Mar 5, 2012
yeah, that plastic piece is probably the culprit. out means lights come one, in means they are off. I would see if you can find another switch at a junkyard or something. or get a new one from advance or something like that. Good luck...
Old Mar 5, 2012
Appreciate it... the switch is good.. it was .. not sure what it is called.. it's the plastic that is on the brake metal part. I placed a replacement "metal" screw.. so when the brake is not pressed.. it pushes and sensor works...
what is that piece called? where the plastic broke on the brake metal itself. It has a hole and placed a metal screw and tightened it... Appreciate all the help... Thanks!
Old Mar 6, 2012
CraigW's Avatar
I would try to find a replacement plastic pin to put back in... or glue the part you found and put it back in place.
Not sure why they use a plastic insert, but they have used them for a while.
Old Sep 15, 2012
75cvcc's Avatar
75cvcc is an unknown quantity at this point
I've attached a picture. I've fixed this problem on nearly all my Civics. Why Honda hasn't corrected this design flaw after 20 years is a mystery to me.
I usually fabricate a little nub for the switch to push on. Just something to fit in the hole that's not to thick, but will not fall out.
Name:	01Civic Brk Ped sw 2.jpg
Old Sep 16, 2012
dont know why they didnt just remove the piece completely and have the switch press directly against the brake pedal metal piece instead. maybe there is a way to adjust the switch reach so it doesnt need the plastic nub.
Old Sep 16, 2012
CraigW's Avatar
^^^ Not sure why they do it that way either. There has to be some reason for it.
Has anyone ever looked at any Toyota models to see if it is done the same way ??
https://www.civicforums.com/forums/a...2&d=1246629503
one of these clips with a nice flat face held with a tiny dab of goop it would last forever.
Old May 31, 2017
Dee Brooks's Avatar
Dee Brooks is an unknown quantity at this point
The proper name for the piece is "Pedal Bushing & Pedal Stop Kit." I just went to NAPA Auto Parts and purchased it. This forum & responses helped me find what the exact problem was and how to fix it.
LionSpratt
Jan 29, 2017 11:07 PM
Rinzlor
Apr 24, 2015 10:33 AM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
liljoe
Nov 4, 2001 01:27 PM
