squeal or squeak when turning left and accelerating
Old Feb 11, 2012
clewis82's Avatar
clewis82 is an unknown quantity at this point
first off im new here so sorry if this has come up before but i have a 2001 lx just hit 100k miles and whenever i turn left and accelerate i hear a squeal or squeaking noise thats sounds like its coming from the left front tire area any ideas what it could be would be appreciated i understand this may be hard to diagnose online
Old Feb 11, 2012
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: squeal or squeak when turning left and accelerating
Power steering pump?
Old Feb 12, 2012
sl33pyriceboi's Avatar
Could be a variety of things like your bearings on your struts
Old Feb 12, 2012
Brake pad wear indicator.
Old Feb 12, 2012
clewis82's Avatar
thanks for all the answers i just changed the brakes not long ago so i doubt its that power steering fluid is full so i dont think its the pump its wierd because its only when i turn left never right the strut and everything was replaced on that side after a wreck like 6 months ago so im not sure
Old Feb 12, 2012
got2run5's Avatar
Does it do it at really slow speeds? Maybe then you could just start turning in your driveway while having someone listen. You might be able to pinpoint weather it's a pump/belt issue in the engine or if it's suspension related.
Old Feb 12, 2012
clewis82's Avatar
yea it does it pretty much regarless of speed thats good advice i think ill have a friend help me determine whats doing it thanks for your help
Old Feb 12, 2012
lowlife9's Avatar
sounds like a loose belt to me tighten the belt.
Old Feb 14, 2012
04 Honda Civic's Avatar
Bent brake heat sheild?
Did it start happening after your front brakes were replaced.
Old Feb 17, 2012
Balzdpr's Avatar
A scene before your eyes
Balzdpr is on a distinguished road
**** man you too? I got this problem as well.
It only happens when I turn the wheel. Not even at differant levels of rototation, only when I first make the turn the sound is consistant in pitch, and duration. You here this as well? I would like to know what that **** is too. I suspect that the power steering pump might have some issues but again its not all the time in fact so less frequent that when I took it to a guy to look at it it didnt even do it.
Last edited by Balzdpr; Feb 17, 2012 at 05:03 PM. Reason: poor ass grammer and spellin'
Old Feb 19, 2012
clewis82's Avatar
i have had to add power steering fluid a couple times but only a little at a time so if its the pump its leaking very slow
Old Feb 22, 2012
Balzdpr's Avatar
Yep. Well thats wierd cause I have fluid showing full and in fact I have always had fluid showing full. And no I have never changed it. Didnt know you could ...if you can. Just thought the stuff ..you know..goes away some how. ha ha ha But seriously if anyone has any input continue posting as im sure the exact answere will arise eventually.
Old Feb 22, 2012
becke8's Avatar
becke8 is an unknown quantity at this point
You said you were in an accident?
Any little bump or tweak to the power steering adjuster (or tensioner), which is basically what drives the power steering belt, can cause the belt to squeek.
I actually just booked my appt for my car to this get fixed aswell.
Good luck!
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Poopies
Apr 20, 2017 11:36 PM
Dorval Andre
May 1, 2015 09:37 AM
GH04si
Apr 15, 2015 08:13 PM
Russps
Nov 8, 2001 02:00 AM
