Heats up and stalls
Old Feb 2, 2012
thegrinch's Avatar
thegrinch is an unknown quantity at this point
Heats up and stalls
I am contemplating purchasing a 2003 civic hx with over 120k miles. I was told there is a problem that when the car heats up, it will stall and can not be started until it cools down. It will turn over but not start. Does anyone have an idea what could be causing this?
Old Feb 2, 2012
Re: Heats up and stalls
Get it really super cheap because it's broken and dangerous.
Then you can afford to have it fixed with all the money you saved.
Seriously. Could be $20, could be $2000.... You don't have enough clues here for me to take even a wild stab.
Old Feb 2, 2012
04 Honda Civic's Avatar
Hmm, I dont think it would be THAT pricey. If its an electrical problem you may not have too much fun fixing it. If your inclined to fix it I say go for it. Make sure it doesnt overheat and make sure the tranny shifts good.
Old Feb 2, 2012
lazlong's Avatar
I'll take a stab at it. I think it's a bad main relay, grounding problem, or a bad connection. Everything heats up and expands, pulling a connection apart.
Old Feb 2, 2012
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Could also be a bad front O2 sensor or ECU. When the car is cold it runs in a closed loop cycle not readong from the front O2. When is reaches operating temp it switches to open loop and takes readings from the front O2 and the MAP sensor. If one of those is bad when is goes open it will flood the car and shut it off and wont start until the car is cool enough to go back to closed loop.
Old Feb 2, 2012
You got open loop and closed loop backwards.
Old Feb 2, 2012
CrewChief's Avatar
Maaaa Baaad. Thanks for the catch. I just re read it and was like WHAAAAT.
Munzy
21
Oct 7, 2015 07:48 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
2.0.0.2
Sep 14, 2015 06:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
thaler4cuse
Sep 7, 2015 08:25 PM
