Annoying Squeaking Noise
Old Jan 26, 2012
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Alright so just the other day my front drivers side started making a pulsing squeaking noise. It doesn't get faster with speed and doesn't squeak at a consistent rate. The guy at autozone said its bushings. Didnt say what kind just bushings. Any input?
Old Jan 26, 2012
wheladan3's Avatar
2001 civic ex
wheladan3 is an unknown quantity at this point
Re: Annoying Squeaking Noise
Does it change when braking, turning, or going over bumps? Is it a rubber squeak or a metallic squeak/
Old Jan 26, 2012
SlimRisk's Avatar
Busy Speeding!!
I believe it's a metallic squeak. And it seems to be the same no matter what
Old Jan 26, 2012
wheladan3's Avatar
2001 civic ex
First I would check all control arm bolts and all the subframe bolts, do not just look try tightening all. Also it would help if you can tell when you here the noise, ie bumps, turning, decel, accel, and if it happens if the right wheel hits a bump and you still hear it on the left side.
Old Jan 26, 2012
Brake pad squealers (wear indicators)??
Old Jan 26, 2012
SlimRisk's Avatar
Busy Speeding!!
@ezone it's not a high pitched squeak like brakes, but more like a stress squeak or metal on metal as if a bushing was broken. I will check all bushings tomorrow night
Old Jan 26, 2012
You trustin a ChinaZone flunky?
Last week he was askin "You want that Soopersized???"
ChinaZone: Whatever they sell is what you need!
If they don't sell it, you don't need it!
/No input from me, just snickers.
Bulletins
01-054 Lower coils of the front springs contact one another
03-039 Lower control arm front bushing
It's over 10 years old, a lot can happen. Body noises?
Old Jan 27, 2012
BlueEM2's Avatar
Whachya lookin at?
Im betting on the lower control arm bushings... I find it kind of odd though because they generally make noise when turning or running over bumps. Another thing to check is to make sure the dust shield is not rubbing on the rotor. hmmmm...
Old Jan 27, 2012
SlimRisk's Avatar
Busy Speeding!!
It seems like it stops when I turn or when im braking. Only happens when im going in a straight line
Old Jan 27, 2012
wheladan3's Avatar
2001 civic ex
If it makes noise on a smooth straight road then possible wheelbearing(that could let rotor contact the backing plate) or the caliper bracket.
Old Jan 27, 2012
04 Honda Civic's Avatar
Spray the top of your struts with some penetrating oil. Sometimes the rubber up there gets dry and worn. This is what my problem was. This is really only a temporary solution until you can change the rubber on the tophats. Or replace them all together.
Old Jan 28, 2012
BlueEM2's Avatar
Whachya lookin at?
^ Good call, I forgot about them.
Old Jan 28, 2012
SlimRisk's Avatar
Busy Speeding!!
Well here's the verdict. Went under my car and all bushings and joints look good. except my passenger ball joint D:< I guess I gotta save up for that next. anyways I found that my driver intake manifold brace unbolted from the manifold, swung down, and was rubbin up on the axle. Also saw my sway bar brackets were missing one bolt on each of the two brackets. Wtff?? But the problems all solved
Old Jan 28, 2012
Wow. Who has been working on your car?
Old Jan 28, 2012
Yea, doesnt sound like a normal thing to me. Sounds more like SOMEONE rather then SOMETHING.
Old Jan 28, 2012
SlimRisk's Avatar
Busy Speeding!!
My bad. Guess i didnt tighten down those down 100% WOT mustve lossened it... Damn
Old Jan 28, 2012
You were the last one to do the work?
Double check your wheels, dont want them flying off on the highway
Old Jan 28, 2012
Buy, learn, and use a torque wrench?
Old Jan 29, 2012
SlimRisk's Avatar
Busy Speeding!!
Lol okay it's a simple thing I overlooked. I make sure to always double and triple check my work because I drive on the highway quite often
Old Jan 29, 2012
But you said a few hours ago.....
Now you say.....
Liar.
What, you just now started triple-double checking your work this evening?
LOL
Man, if I did work like that, I wouldn't have any real customers left.
I would have to bribe the AAA tow truck drivers to drag dead ones in off the interstate to me. Then they'd be trapped like rats, I could keep the cars for 6 weeks while I install self-destruct parts. Muahahahaha.
Old Jan 29, 2012
BlueEM2's Avatar
Whachya lookin at?
Now Now. At least he is willing to do the work himself. A lot of people on here take it somewhere!
Old Jan 29, 2012
True.
Hey, I wrote LOL in there....I wasn't really trying to be harsh.
You didn't catch the reference to the "Legal Advice? Help Needed. Calling all Members" thread?
Old Jan 29, 2012
SlimRisk's Avatar
Busy Speeding!!
@ezone I caught that reference lol good one
Old Jan 29, 2012
Lol I got it as well, still harsh.
Anyway, just becareful you seriously need to double check your work.
If I am doing something on my car, I check **** over and over even if I KNOW I got it right.
Its the beauty of working on your car the amount of detail you can pay attention to because your not getting paid per job.
Old Jan 29, 2012
Come on, wasn't the LOL good enough?
Dang, tough crowd in here.
Hey, if *I* screw something up I get to do it over for free. It behooves me to do it right the first time. That's the way my pay plan works.
If I have to fix someone elses' problem, their time sheet gets docked to pay me for mine.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
