02 Civic EX coupe rear speakers 6x9's what brands fit???
Hello,
I am upgrading my stock system and need some help.
I put 6.75" Polk components up front (custom fit) and a JL audio sub in the trunk.
The problem is that I want to add rear fill with new speakers in the rear deck. Crutchfield says only certain 6x9's will fit..I am wondering why and if any of you guys could tell me what fits in your cars? Sony? Polk?
I have at least 3.25" of bottom depth before I hit the tension bars but Crutchfield says that some speakers with less than 3" of bottom depth won't fit. I find this strange unless there is a top fit issue...
What kind of speakers does everyone have that fits???
Thank you!!!
Thank you!!!
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Re: 02 Civic EX coupe rear speakers 6x9's what brands fit???
search the DIY section..there are posts on how and what to do for the rear deck..check the 7th gen DIY.. I am not sure which ones fit without removing your torrsion bars..
Ok. So Duals fit. good. I chatted with Crutchfield and they said the issue was the top mounting depth. I asked him what the limit was and he said anything over .499" you would have to modify it. Not sure what measurement that is ..half inch?? But the Alpines that they say fit have 2 13/16 top depth.
I will check the DIY area too.
I just finished putting infinity reference 2-way 6x9s in back. I kept my trunk springs in. They fit after I:
1.) Used the (.5 in ?) spacer that came with the speakers
2.) Put a washer (yes, it was that close of a fit) under one of the rear screws in each speaker.
3.) Dremmeled off the lip on the underside of the rear deck that surrounds the speaker so the rear deck would fit over the speakers.
Took a lot of work, but the speakers sound awesome.
Yeah, I figured most speakers back there would require some extra work to get them to clear the rear deck. I actually picked up some Sony 6x9's with a gift card I got for $50. Decent and cost effective. I got my top of the line Polk components up front and just wanted the back for rear fill. I am going to try and see if they will fit and work back there..
I wonder if I should even use speakers back there??? I am sending 100 watts RMS to the front components of my amp and just running the rear 6x9's off the JVC head unit with a 300 watt RMS JL Audio sub in the trunk....
IMO you should still put them in..only cause it will help balance the mids(and highs if 3-way) with the rest of the bass. It will help deliever a more quality sound..which is what i like..i never build a system to rattle my bones like i used to anymore..i like good quality sound with bass..
I agree. I want the full sound. I went with a sealed box with a quality sub for that reason.
Yeah im in my thirties now and the wife does not see eye to eye with me when it comes to my car..right now i am looking to upgrade my system..probly gonna just get one 10 or maybe dual 10s with only like a 2-300 watt amp..im not trying to go deaf just want some good sounds..
I've always liked a single 12" sub in a sealed box. Tighter bass, less boomy and you get to save on trunk space for the groceries and stuff. I went with the 300RMS JL AUDIO 12" 1w2 with a Sound Ordinance 4 ch amp Putting out 270 RMS to the sub and 100 RMS to the components. Should sound good. I am getting the new amp back from Crutchfield today and will FINALLY turn everything on to hear it!
Update: I ordered some Alpine SPE-6090 6" x 9" Type-E Coaxial 2-way Car Speakers which should fit with the height restrictions of our cars. But even without them installed yet my audio system sounds AMAZING so far!!! I highly recommend Polk Audio componets and JL Audio subs!!! Running them all of an Sound Ordinance M4100 amp. Had to send first amp back but the second one has tons of clean power.
lilbluecivic
Nov 7, 2001 06:49 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
