Performance Radiator Choices
Busy Speeding!!
1 Post
Rep Power: 170 Performance Radiator Choices
My radiator is falling apart, the fins move with the slightest touch and sometimes fall out on their own. Majestic wants $200 for a new denso radiator, and I said, yeah no way. So I thought to myself, I could get a performance aluminum radiator and it would work for 100,000 + miles for my car and when I eventually do a K-Swap. Just wondering what kind of performance radiators are out there for me? I havent seen any d17 performance radiators out there.
Live for the Twisties
Rep Power: 261 Re: Performance Radiator Choices
I could be totally wrong here, but does it matter what radiator you use as long as it exceeds the requirements of your engine?
Hybrid Racing supplies k-swap rads.
http://www.hybrid-racing.com/products/hr-radiators/
Rep Power: 788 Re: Performance Radiator Choices
all metal is the way to go. they need to be sized properly to cool the engine depending on your driving conditions and whether you have an a/c condenser in front of it.
Rep Power: 188 Re: Performance Radiator Choices
$100 from these guys
http://performanceradiator.com/locations.php
I'm picking one up on thursday, just call and ask someone
1 Post
Rep Power: 328 Re: Performance Radiator Choices
i believe u meant to say aluminum. they dont make metal alum. it corrodes and doesnt transfer heat as well as aluminum
Busy Speeding!!
1 Post
Rep Power: 170 Re: Performance Radiator Choices
I was considering going with mishimoto or koyo. I have an 01 lx manual with a/c. It gets pretty cold in the winter, but also hot in the summer. Lots of hard accels and more highway driving than city.
@MindBomber
Hybrid Racing doesnt carry rads for our d17 k swap
http://www.hybrid-racing.com/store/i...ling/radiators
But cant I just use a d17 rad in my k swap? possibly with slight mods?
@MindBomber
Received 1,156 Likes
Rep Power: 485 Re: Performance Radiator Choices
I was wondering about the same thing with the d17 radiator and a k-swap.. I dropped a koyo radiator in mine after mine leaked (due to finding a knife between the fan and the radiator).
Dezod and thmotorsports carries them.
Busy Speeding!!
1 Post
This is what I found on Hybrid Racing about EG K-Swaps:
These radiators simplify the K-series engine swap by eliminating the need for custom mounting brackets and by providing a guaranteed fit for your specific swap. That means no cutting is required whatsoever. This radiator integrates the necessary ports for the Coolant Temperature Sending Unit and the Fan Switch, eliminating the need for a Hybrid Racing Radiator Hose Insert. There is also a grounding bung welded to the lower end tank to guarantee that the sensors mounted to the radiator get a good ground connection.
A scene before your eyes
@MindBomber
@MindBomber
Ill just assume you got the standard, cause im the only one here most like rocking the auto.
Busy Speeding!!
1 Post
Mishimoto carries a good replacement alum rad for all makes if standard Tranny. Otherwise there might be some difficulty finding one there. I have located one there recently for my 05 and have the issue of needing a tranny cooler attachment due to the missing transmission cooling hose on the rad.
lol i didnt think radiators came in anything other than aluminum. copper maybe? but $$$
Busy Speeding!!
1 Post
Ill post a pic of the piece that fell out. its for sure copper. most of it has corroded but wipe it away and its copper. But copper is such a soft metal, heck water corrodes it, coolant will beat the **** out of copper. Choice for radiator? copper < aluminum
Received 1,451 Likes
Rep Power: 339 Re: Performance Radiator Choices
dezod had the koyo 10% off until 12/2?
It's mined from the cores of asteroids, the density would make it a very heavy radiator haha
Thats insane man. Why would they make the standard out of a material that is so corrosive, when the potential for water to be in there is so high?
cause in the end, its a cheap econobox lol. i asked myself that question the first time i opened the hood. why does the radiator have plastic on it?
trying to keep weight down one doesnt want to add any additional componants or hardware to his or her car. If I buy a aluminum RAD from Mishimoto I have to also buy a trans cooler to make up for the lacking coolant hoses for the tranny. What other reliable options are there? Or should I just suck it up and ad the cooler.
OptimisticWay
46
10-15-2015 02:16 PM
liagreenhalgh92
07-21-2015 01:31 PM
Kyles24
07-12-2015 09:15 PM
CivicsClass101
07-09-2015 11:14 AM
