May have messed up on timing belt install
Old 09-14-2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
So I finally got everything apart and was trying to remove the lower timing belt cover when this wire bundle was preventing me from getting it out, I didn't want to stress the wire so I unhooked it.
It turns out it was attached to the CKP sensor, the sensor that points to the crank pulley.
In the DIY article from this site I was following (not well enough apparently) it said not to disconnect this wire.
I did not rotate the engine at all, the original timing belt is still on, all I did was unplug it, then I realized my error and plugged it back in without doing anything else. I'm just afraid I messed something up because it said NOT to unhook this wire, to unbolt the sensor instead.
Also, how do I rotate the motor to get to TDC with the crank pulley off?
Thanks in advance.
anibis is offline
Old 09-14-2011
Received 1,159 Likes on 807 Posts
Re: May have messed up on timing belt install
You're fine disconnecting it. It works off a magnetic signal or something. That said, be careful while handling that sensor. If you drop it, bump it hard, or anything, it may damage the sensor. You'll know if you damaged it. It'll throw a CEL, take absurdly long to start, and you won't be able to rev past 3000
As for going to TDC, I temporarily put the pulley back on and rotated it with that.. Didn't bolt it on, just slipped it andthr woodruff key on.
xRiCeBoYx is offline
Old 09-14-2011
Received 1,456 Likes on 1,207 Posts
mine was one piece when i started and was 2 pieces when i was doing (overtorque )
sdaidoji is offline
Old 09-14-2011
anibis's Avatar
Ahh good, I was afraid I did something wrong although I couldn't figure out how unplugging it would cause issues. I will be careful with it though.
My car has 120k majority city miles and the timing belt looks as if it could have broken at any time, I'm glad I decided to change it now.
Next up, wheel bearings.
Thanks guys.
anibis is offline
Old 09-14-2011
anibis's Avatar
I saw in a different DIY on youtube that you can rotate the motor using the cam bolt too. This isn't ideal imo but it got me to TDC. I had to use a puny wrench thanks to the stupid ABS box.
Hopefully she'll be runnin like a champ tomorrow and I won't have to do this again for 100k.
anibis is offline
Old 09-15-2011
look at the headgasket link I have in my sig. There's a lot of tips and tricks to help with a timing belt job. Also, the link at the bottom of my first post in that thread helps a lot, too.
And going to TDC with the cam bolt.. You need to match both the cam gear at TDC as well as the crankshaft at TDC. When I set it, I temporarily installed the lower timing cover and slipped on the crank pulley, lined that up to TDC (and double checking cylinder 1 at it's highest point with a dowel), made sure the camshaft was set for TDC, then slipped the belt on. Afterward, with the belt and tensioner set, I went through 2 rotations of the crank pulley, then double checked the timing marks.
S.Klinck
02-10-2016 02:19 PM
S.Klinck
06-11-2015 10:27 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
bsmiley
04-27-2015 01:27 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: May have messed up on timing belt install
