Which bolt in the center console to adjust ebrake?
Old Sep 10, 2011
Civicnoobie's Avatar
I am Epic
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
Just need to make sure, im trying to do it by hand but its cutting up my hand. No way i can get a 10mm down there it wont even grip
Old Sep 10, 2011
lazlong's Avatar
Re: Which bolt in the center console to adjust ebrake?
It's in the rear of the console. You may need to remove the console to get to it.
1. Remove the 2 screws on either side in the back.
2. Remove the top portion around the e-brake handle:
3. Remove the 2 screws in the front portion of the cavity you just uncovered.
4. Remove the 2 screws on either side in the front
5. Twist off the shift **** then pull the top ring of the shift boot off the shift lever
6. Pull entire console up and back
This is for a manual trans. If you have an auto trans then it's a little different but, you get the idea.
Old Sep 10, 2011
I am Epic
Thanks i got the plastic part that goes around the ebrake handle off.
Heres a pic. See the silver bolt in the middle of the big metal piece, is that the one to adjust clockwise?
rman1900
21
Sep 10, 2018 04:52 PM
GotSiR
Jun 23, 2016 04:06 PM
sccarally
Texas
Aug 21, 2015 10:09 PM
WaryDriver
Aug 8, 2015 05:08 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
