Door Lock Actuator Slipping?
Old Sep 10, 2011
2002ExCivic's Avatar
2002ExCivic has a spectacular aura about2002ExCivic has a spectacular aura about
My passenger door lock actuator sounds as if it is slipping. There is noise when I use both the button on the drivers side and the key fob. Last time I took the door panel off I checked the actuator by testing it, and for some reason it worked. The next day it didnt work, felt like the actual lock was stuck or the actuator was slipping.
Has this happened to anyone?
What can be done to fix this?
If I replace the actuator will the problem go away?
Thanks in advance.
Old Sep 10, 2011
sl33pyriceboi's Avatar
Re: Door Lock Actuator Slipping?
The actuator will either work or or doesn't. If it locks/unlocks ur door then it works. If it doesn't then you need to get it replaced. There is a DIY on here. It's not hard
Old Sep 10, 2011
CraigW's Avatar
My passenger side on my 05 was similar. It got slower and sluggish over time on the unlock. And more noisy. When it got to the point it would sometimes not lock properly I replaced it.
I noticed that if you worked the lock/unlock several times it would return to normal speed for a while until it sat.
When the car has been sitting a while and unlocking look at the speed of the lock **** to see if it is slow/sluggish on the unlock.
I think your actuator is the problem. It is just a little DC motor with a worm gear. Very common to fail on 7th gens.
Old Sep 10, 2011
Thanks guys, I have done my drivers side door.
I also bought the actuator a month ago.
I just wanted to know if I really had to replace it or not.
I'll do it later today most likely.
Sep 26, 2023 06:44 PM
breanna_17
Jul 21, 2015 04:01 PM
Jul 12, 2015 11:54 AM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
