Coil or coilover
Old Sep 6, 2011
max785's Avatar
max785 is an unknown quantity at this point
Coil or coilover
Hi . I need you help to choose between both . Here where I live the is alot of snow . So each winter I can't drive so low . If I buy coil , I will need to change the spring each winter . But with coilover I don't know if this is good to keep them in the winter ? btw it's a civic 01
Old Sep 6, 2011
MindBomber's Avatar
Live for the Twisties
Re: Coil or coilover
Why it would not be a good idea to keep them in the winter?
They're suspension components just like any other and can be used year round, just adjust the ride height in the winter to give you more ground clearance for driving in snow. If you want full coilovers you should be budgeting a minimum of $900.
Old Sep 6, 2011
max785's Avatar
Because I heard storie with jammed coilover :/ yea I have a 1200$ budget . I will buy them this winter and put them at spring time . My choice was tein basic .
Old Sep 6, 2011
MindBomber's Avatar
Clubrsx has tein basic for $880.
Coilovers seize because people don't maintain them properly, they just set them to the height they want and when the nuts are stuck years later they go complain. Coat the threads with anti-seize or moly bearing grease a couple times over the winter and give them a good cleaning with brake cleaner and you'll have no issues
Old Sep 6, 2011
max785's Avatar
only 880 . tein are good coilover no ?
Old Sep 6, 2011
MindBomber's Avatar
Tein is without question one of the best coilover manufacturers, especially if your looking for a comfortable street ride. I have Tein SS and absolutely love them.
The reason the basics are only $880 is because that's they're entry level coilover, the only other coilovers I would consider under $1000 are Progress.
Old Sep 6, 2011
max785's Avatar
you ride ss with a em2 ? if yes , what the difference with both ?
Old Sep 6, 2011
MindBomber's Avatar
Yes, I have them on an em2.
Are you asking for the difference between SS and Basic or Basic and Progress?
The difference between the different Tein dampers, without going into major details, the SS are dampening adjustable and the Basics are not. The best way to compare the two would be to go to Tein's website, I could describe the differences but I'd basically just be paraphrasing their website.
Old Sep 6, 2011
max785's Avatar
I don't even know what the dampening do XD
Old Sep 6, 2011
MindBomber's Avatar
Okay, here's the ultra simplified coles notes of a coilover.
The body of the coilover is the part designed for a specific model of car, that's the metal body that bolts to the knuckle and tie rod, including the adjustment threads. The damper is the part that makes the difference between a $350 POS Rokor coilover for ricers and a $10,000 Moton or Penske coilover that professional race teams use. The damper is the shaft and valve body that compresses and rebounds inside the body of the coilover. A damper ranges from being non-adjustable up to three way adjustable, basics are non-adjustable and SS and Flex are single way adjustable. The single adjustment gives you the ability to vary the stiffness of the damper, from almost stock softness to very stiff.
Old Sep 7, 2011
lowlife9's Avatar
don't get tien basics get Progress basics don't go low enough and tend tp blow prematurely when lowered to there maximum setting.
Old Sep 7, 2011
max785's Avatar
oh I understand now so tein ss or progress basic ??
Old Sep 7, 2011
MindBomber's Avatar
I vote Tein SS, but I'm a bit biased haha.
Here's a review on Tein SS another member wrote.
https://www.civicforums.com/forums/1...vers-edfc.html
Old Sep 7, 2011
max785's Avatar
What biased mean ? Sorry english not my main language XD
Old Sep 7, 2011
lowlife9's Avatar
tien ss are good coilovers but cost alot more then progress with the money you save buying progress you could get some needed suspension upgrades.
Old Sep 7, 2011
MindBomber's Avatar
Bias means I have a reason to prefer Tein SS (owning them).
Old Sep 7, 2011
max785's Avatar
like camber kit ?
Old Sep 7, 2011
max785's Avatar
oh ok :P
Old Sep 7, 2011
lowlife9's Avatar
sure maybe ball joints or compliance bushings you never know whats going to be needed.
Old Sep 7, 2011
max785's Avatar
ya , and my shock are doing TOK sound when I pass a hole or sometime like that. Maybe the top plate ?
Old Sep 7, 2011
MindBomber's Avatar
The bearings are probably shot, that's a cheap and simple fix.
Old Sep 7, 2011
max785's Avatar
can I do it easily myself ?
Old Sep 8, 2011
Civicnoobie's Avatar
I am Epic
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
the basics blow easy? damn would want that. Dezod has the progress basics for $1043, is that good price?
I think this is it
http://www.dezod.com/pd_progress_cs1...civic_0103.cfm
It says exc SI so im guessing it wont work on SI?
And what is the upper mounts do? Do we want them?
Old Sep 8, 2011
lowlife9's Avatar
its because the si uses 16mm bolts the 2001-2002 use 14mm bolts but all you would need to fit would be to drill out the holes 2mm the 03-05 civics also have 16mm bolts. you want the plastic upper strut bearings from the 2001 ther like 25 bucks you would want to replace your bearings regardless.
Tedverseti
Apr 23, 2020 01:45 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
