Passenger seat does not slide forward anymore
02 coupe DX
So the other day my passenger seat stopped sliding forward when you pull the side handle, or push the pedal in the back. I tried looking around under there and see it connected by like a bicycle brake cable. The seat still pops forward, but does not slide. The seat slides fine if I pull the main handle under the seat, with no problems. Any advice or input?
1 Post
Rep Power: 170 Re: Passenger seat does not slide forward anymore
If you don't see the cable under the seat move when you pull the side handle, then the connector has broken or disconnected. No idea how to fix it though.
Did all years Civics allow the passenger seat to slide forward when pulling the side handle? I have a 94 that doesn't and just assumed it was supposed to be that way.
02 coupe DX
I am not sure if all do or not. I also am not sure if I would be able to see the cable move as it is encased, and the steel cable slides inside. It isnt a HUGE deal, but very inconvenient at this time because I am so used to it rocketing forward.
Rep Power: 788 Re: Passenger seat does not slide forward anymore
must be a coupe right? yeah you will have to take the seat apart and see what broke so you can replace the part. there is nothing you can do with the seat installed.
02 coupe DX
17
07-23-2015 11:48 PM
jessicanicole
07-23-2015 09:14 AM
