engine went....
Old Aug 26, 2011
tjwrestling's Avatar
2002 civic dx coupe
tjwrestling is an unknown quantity at this point
engine went....
My engine went in my 2002 civc dx coupe. I plan on either putting a new engine in or rebuilding the old one. Im not sure on what to do. Anyones advice would help and id be thankful for it.
Old Aug 26, 2011
Brian1037's Avatar
Sedans > Coupes
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
Re: engine went....
If you're into performance and want to build your car then this is the perfect opportunity to swap in a k-series engine. It's expensive.
Otherwise, if you just want a daily driver and don't want to spend much money then you can either rebuild yours (you could probably get a quote on that) or swap in a new D17A1 (the same as your engine you had) or a D17A2 which is basically our engine but with VTEC (it's from the Ex model). I've seen D17's on Kijiji for anywhere from 400-900$ but if you want to get it installed professionally then you're going to spend more.
If I was in your position I'd at very least put in a D17A2 with low miles, but probably instead go for a K20. Good luck
Old Aug 26, 2011
2002 civic dx coupe
Re: engine went....
thanks for the advice. Im probly just gonna do the rebuild. but i have looked into do the swaps which would be nice to. before this happened i was gonna do the d17a2 head swap for the vtec. but to save money im just gonna do the rebuild and do it myself.
Old Aug 26, 2011
Brian1037's Avatar
Sedans > Coupes
Re: engine went....
Yep that's another option. When you get a quote let us know what the cost is, I'm just curious.
Old Aug 26, 2011
2002 civic dx coupe
Re: engine went....
You can get d17a2 vtec head for about 400 bucks but in my case i would need to get a vafc 2 controller to bypass the ecu which is another 160-200 bucks. if you dont do it that way you have to get another ecu and get your key reflashed which costs alot. but i can get a new engine block and a rebuild kit for 450 bucks so im just gonna do it that way.
Old Aug 27, 2011
brobo's Avatar
brobo will become famous soon enoughbrobo will become famous soon enough
Re: engine went....
if u want i have a complete d17a2 vtec engine with 55k miles with papers
asking 900 obo located in cleveland
Old Aug 28, 2011
2002 civic dx coupe
Re: engine went....
I will for sure keep that in mind. I dont have the cash right now so its gonna be a little before i start to do anything. but thanks for letting me know. Is the engine clean?
Old Aug 28, 2011
brobo's Avatar
Re: engine went....
its been sitting but its clean
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
