CV Axle Install Problems
Old Aug 20, 2011
Jburr's Avatar
Jburr is an unknown quantity at this point
Hello all my name is j ive lurked the forums for a while as kablinfect but hes not allowed to post so ha.
My problem happened when i attempted to replace my CV axle myself. i have some experiance working on cars so i thought this wouldnt be much of a problem. removing the axle wasntto much of a problem but when i attempt to install it it will only go halfway. so i hammered it in . Test drove it and still heard clicking so asked around and i was told your not suposed to hit it and it should go in easy.
SO not im trying to ease it in and no progress with that. My question is are the spleens suposed to match identically? Mine have four gaps like below and the male inlet has no gaps? plz help me out.
Name:	Female Spleens.jpg
ID:	81553   Click image for larger version
Name:	Male spleens.jpg
Old Aug 20, 2011
Jburr's Avatar
Re: CV Axle Install Problems
Also forgot to tell you all its a 03 Honda Civic coupe. the new CV Axle is identical to the one i removed so curious to what im doing wrong.
Old Aug 20, 2011
MelJ's Avatar
Trance Addict
I'm viewing from my phone, but I'm assuming you're talking aboethut the axle that goes into the differential? If so, it takes some time to work it in there properly. It took me maybe a good 10 minutes. Make sure that ring is on there good as well. Hammering wasn't a smart idea either. I doubt you ruined anything, but don't do stuff like that to things with threads, teeth, splines, etc.
Old Aug 21, 2011
Hardcoresteve's Avatar
Hardcoresteve is an unknown quantity at this point
I had the same prob with my 05. The issue was the clip on the end was too big. Maybe try n get a set of different clips(i jus borrowed the old ones but idk if I would reccomend that)
^ but like was said make sure the clip isnt getting caught n maybe try some grease to keep the clip in place and turn the axle as u work it in...may still take a little tappy...but dnt beat on it too much
Old Aug 21, 2011
lazlong's Avatar
Yeah, it took me like ten minutes to work mine in too. It took a lot of giggling back and forth.
Old Aug 21, 2011
MelJ's Avatar
Trance Addict
Red face Re: CV Axle Install Problems
You never reuse the circlips. The old one may be worn and won't hold properly.
Old Aug 21, 2011
lazlong's Avatar
X2. Rule of thumb is to never re-use gaskets either. It's just cheap insurance.
Old Aug 21, 2011
I said I wouldnt reccomend it. But if the clips on his r anything like on the cheapo axles I got from advance auto then he might need to pick up other clips was my point.
I believe ur supposed to replace them every time u remove the axles so im sure they got em individually at the dealer.
Old Aug 22, 2011
Jburr's Avatar
Thx for the info guys but still having a problem with the last 1/8 of an inch not going in all the way. not sure why it wont go in all the way.
Old Aug 23, 2011
Do u have auto or 5 speed? Thanks to the retards at advance auto I jus happen to kno that the auto trans axles will go in but dnt fit in far enough if u have a 5 speed...make sure u got the right axle
Old Aug 23, 2011
MelJ's Avatar
Trance Addict
. You make a good point there. Didn't even think of that. You gotta check the part numbers just to make sure they don't eff anything up if you go to Advance.
Old Aug 25, 2011
Jburr's Avatar
Its a 5 speed. matched the one i took out.
4 banger
Jun 5, 2015 01:44 AM
beveragemp
May 25, 2015 07:11 PM
Youshoe
May 22, 2015 09:36 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Flatlander
Nov 16, 2001 05:38 PM
