Sealing Headlights
Old May 14, 2011
Shift-E's Avatar
That Dude with the Questions
Sealing Headlights
Whats the best way to seal your headlights once their opened? I've noticed some people just heat it back up and press it toghether with the existing sealent, while others say to remove the old sealent and put new sealent.
New sealent sounds like it would obviously be better, but taking off the old sealent is a pain in the ***.
With the old sealent, im afraid if it would leave air bubbles/leaks where water vapour or dust could get in.
Which is the better route to go? (First timer)
Old May 14, 2011
Re: Sealing Headlights
the existing sealant method used to be popular here but it doesnt always work. once the original seal has been broken, its very hard to get it perfectly sealed again. i would recommend adding more of a butyl based sealer like 3m windoweld ribbon or similar stuff autozone and napa sell that comes on a roll and is sticky. and use heat along with some pliars to clamp them back together one section at a time. do it right the first time otherwise you will have to open it again when all sorts of water gets in and causes fogging. you can add extra sealer to the oem stuff without scraping any out.
Old May 14, 2011
Shift-E's Avatar
What do you think about removing the old sealent (well as much as you can) and applying new sealent all around? Cuz I kinda already removed the sealent from one headlamp.. :P It was a pain! then I decided to post to see if I could use the old sealent for the second one.
Old May 14, 2011
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
Just thought i'd add in: These are ebay headlights and not oem so the sealant probably isn't as good
Old May 14, 2011
it should be similar enough. all the aftermarkets ive tried have the same grey or black stuff like oem. but yeah there is no problem removing the oem stuff if you want and using all new sealer. thats what i did with my retro, mostly because its been apart so many times the sealer was coming off lol.
Sep 27, 2015 11:33 AM
shaejb15
Sep 12, 2015 01:02 AM
Rexall
Sep 11, 2015 02:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
