here goes nothing.
Old Apr 26, 2011
lowlife9's Avatar
here goes nothing.
went to the dealer today to get automatic trans fluid and all they had was the new ATF-DW-1. im driving a 04 that doesn't have the best shifting so im praying it doesn't start slipping on me wish me luck.
Old Apr 26, 2011
MindBomber's Avatar
Live for the Twisties
Re: here goes nothing.
Good luck, keep us updated please.
Old Apr 26, 2011
mvanbv00's Avatar
mvanbv00 is an unknown quantity at this point
I did this two weeks ago. Seems like it shifts a little bit smoother, but its not too noticeable. The only noticeable difference is when I'm going 35-40 mph and I let off the gas and get back on, it doesn't jerk anymore.
I don't know if this is slipping but can someone tell me if this is normal? As I accelerate from 30-40(45 ish)mph my rpm goes up then down then back up (AT within the same gear). Numbers are approximations, I don't remember actual numbers, bu this is what is happening.
30=2500 rpm
35=3000 rpm
35-37= 2800 rpm
37-40= 3000 rpm
40-45= 3200 rpm
And good luck. Keep us updated with your experience.
Old Apr 26, 2011
lowlife9's Avatar
did that happen before you added the new fluid ??? the only thing that scares me is the lower viscosity of the new fluid on my used trans. i will keep updates.
Old Apr 26, 2011
mvanbv00's Avatar
That has been happening since I can remember. I got the car with 27000 miles. i have 63xxx now. It did get slightly better but not much. I am going to do another drain and refill at the next oil change.
Old Apr 26, 2011
lowlife9's Avatar
is your car doing this ??? wtf i guess you can't imbed youtube video anymore ??? search ''slipping tranny 2'' on youtube.
Old Apr 26, 2011
mvanbv00's Avatar
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=107&t ransactionid=1303869210-1732305886&posted_by=mvanbv00_www.civicforums.com& youtube_video_id=vJRiq2xxWxo[/autostream]
More like that, except when the mustang stays at 4k rpm in second mine goes down 200 rpm or so, then back up. it only happens when I accelerate moderately. Not flooring it or granny driving, just normal acceleration.
Old Apr 27, 2011
BlueEM2's Avatar
Whachya lookin at?
Good luck man... considering a manual swap if the tranny goes?
Old Apr 27, 2011
lowlife9's Avatar
hell no if the trans goes ill burn it.
Old Apr 27, 2011
MindBomber's Avatar
Best response I've ever heard to trans problems lol
Old Apr 27, 2011
7genmarathon's Avatar
7genmarathon is an unknown quantity at this point
I thought the viscosity was higher in this newer formula. I read on the back it was but that was back in mid march I might be brain-farting.
I got the dw1 in my AT as well. I figure its a matter of when, not if....
Old Apr 27, 2011
lowlife9's Avatar
nah im reading it rite now it says ''lower viscosity for better gas mileage''. i do however have a single quart of old fluid i forgot i had so im going to use that with the new stuff then the next change go full synthetic.
Old Apr 27, 2011
sl33pyriceboi's Avatar
winning.
Old Jun 27, 2011
lowlife9's Avatar
today i finally did the switch over i added 2 bottles of the new stuff and one bottle of the old fluid . it seems to be shifting normally will see how it does down the road.
Old Jun 27, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
I think you should have tossed the Z1 and gone with DW1 only , I've been going on thousands of miles with no negative change in shifting performance or transmission behavior (after two drain and fills, aka 70% DW1).
Here are my arguments (beliefs) in favor of DW1 being safe (same title, but two different posts):
https://www.civicforums.com/forums/1...ml#post4539093
https://www.civicforums.com/forums/1...ml#post4539391
Old Jun 27, 2011
lowlife9's Avatar
well i had one extra bottle left that couldn't be returned mixing them won't do anything i mean the fluid stuck in the converter is still the old stuff i just did one drain and fill not a complete flush. my next drain will be straight synthetic stuff.
Old Jun 28, 2011
BlueEM2's Avatar
Whachya lookin at?
HAHAHA good answer... Before you burn it send me some parts though.
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
rnaodm
Sep 21, 2015 12:42 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Dave Brabant
Sep 9, 2015 08:11 PM
Klame9420
Sep 7, 2015 10:03 PM
