How to jack-up lowered car.
Hey, I realized that with just even a small drop, my floor jack (not low-pro) JUST cleared the front bottom bumper by lifting at the center point of the sub-frame.
The saddle pad to lift is actually 5", but the rest of the body is pretty high, and I have to stick the jack pretty much under the whole front of the car to reach the center sub-frame jack point.
Well, got me thinking, it definitely wouldn't fit with anymore of a drop.
How do you guys jack your car up?
Was thinking to use a scissor jack on one side to give me just enough room to slide a floor jack to the center point to life vehicle evenly. And then I would use jack stands on the side rocker lift points.
Re: How to jack-up lowered car.
Before I even finished reading your post the 1st thought that came to mind was to use the scissor jack.lol.
Just crank it up on the chassis near either tire on a level surface enough to squeeze a floorjack onto the main jack-point in closest to the bumper
or use ramps - prefferably the ones that does not slip
- i am happy for having select the pro-kit sometimes :P The miata is already hard to place the jack now, stock, i am scared when i finally put some springs on it...
- i am happy for having select the pro-kit sometimes :P The miata is already hard to place the jack now, stock, i am scared when i finally put some springs on it... Last edited by sdaidoji; Apr 14, 2011 at 06:59 PM.
yeah mine is the same way like 2mm for the jack to slide under lol. the only part i miss is i used to be able to change the trans fluid when the car was stock without raising it up. now its too low to fit under.
Civic15
18
Sep 19, 2017 07:48 PM
alxz310
Jul 30, 2015 12:18 PM
Jul 12, 2015 11:54 AM
CivicsClass101
Jul 9, 2015 11:14 AM
