2001 civic, left headlight wiring problem
Old Mar 30, 2011
rr44's Avatar
rr44 is an unknown quantity at this point
Hello, My left headlight is out (I check bulb and fuses and the plug all good)
I checked the wires with a test-light at the plug and have power at both the red/white & red/yellow wires.
When I check the red/blue wire (ground?) I checked with tester hooked to power and it barely lights up very faint though.
From looking at the haynes wiring diagram the red/blue seem to go to the under-dash fuse box.
I'm thinking of of just tapping an extra ground from the frame to the red/white, bad idea?
Thanks for any help.
Old Mar 31, 2011
CraigW's Avatar
Re: 2001 civic, left headlight wiring problem
The bulbs are provided +12 volts to the common terminal (left = RED/YLW). The grounding path is provided through the headlight switch for either the low beam leads or the high beam leads.
The correct wire color for the low beams is RED/WHT. red/blue is for high beams.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
mattdoc
Mar 14, 2017 12:10 PM
lilbluecivic
Nov 7, 2001 06:49 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
