Custom Sub box
Old Mar 17, 2011
whitecivic2003's Avatar
whitecivic2003 will become famous soon enough
Custom Sub box
Finally finished my sub box and installed it. just need to put the grill on . Sounds great.
here is a picture sequence
Size:  46.0 KBName:  101_0802.jpg
Size:  60.9 KBName:  101_0822-1.jpg
Size:  86.4 KBName:  101_0837.jpg
Old Mar 18, 2011
What_It_Do's Avatar
What_It_Do will become famous soon enough
Re: Custom Sub box
Good job, for sure.
Old Mar 18, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: Custom Sub box
Looks really good,
Really nice end results
Couple questions:
What's that material you used to cover it?
You decided not to go with a speaker terminal and routed the wires inside only?
Is that like 12 Gauge speaker wire?
Any pictures of inside?
Would like to see how you bolted it down
Old Mar 18, 2011
Re: Custom Sub box
Originally Posted by What_It_Do
Good job, for sure.
Thank you.
Looks really good,
Couple questions:
What's that material you used to cover it? Marine Vinyl it has good stretch capability. the local upholstery shop just let me go through their rack and pick something out.
You decided not to go with a speaker terminal and routed the wires inside only? I dont like terminal cups they are normally thin plastic and creating a bigger hole increases the possibility for air leaks. i also use silicone 1 to seal the wire to the box from both sides.
Is that like 12 Gauge speaker wire? Good eye, yes 12g twisted with plastic shield.
Used foam seal tape then neoprene washer ,metal washer and nylon lock nut. to secure the bolt to the car i went through the trunk brace and used fender washers and nylon lock nuts so it would not spin on the nut inside the box.
And thanks for the comments.
Old Mar 18, 2011
Kenny the Ricer
Re: Custom Sub box
Really good job on the sub box
I think I'll keep my eye out for that Marine vinyl, looks awesome
The only reason I would get a speaker terminal, is because I can remove the speaker if need be easily, it can be easily sealed by silicone all around since they have a lip, and can also be fiberglassed inside
But as long as it works for u, its all good
And I was wondering why only 12 gauge.
Didn't you say you were powering it with a 500/1v2?
I would go at least 8 gauge on sub wiring with at least Monster/JL/Rockford wires
But that's just me
Do you have a MDF floor board
I would have thought you to bolt it to the floor lol
But again, really great job
Old Mar 18, 2011
Re: Custom Sub box
Thanks Kenny
Yea I thought about using the terminal but I designed it so that it wont come out easily.
also the reason for using security screws on the speaker. No I don't have a mdf floorboard wanted to keep the weight down some. And as far as the speaker wire gauge the voltage loss was minimal for the 5 foot run. Found this cool calculator for the loss numbers check it out . it was a 4 watt loss at the speaker.
http://bcae1.com/images/swfs/speaker...rassistant.swf
Thanks again for the support
Old Jan 5, 2012
Re: Custom Sub box
Picture with Grill and on the finished amp rack.
Size:  77.6 KBName:  100_0811.jpg
Old Jan 5, 2012
Kenny the Ricer
Re: Custom Sub box
That is one sexy amp rack
Lovin it
Howd you get the glass to curve?
Old Jan 5, 2012
Re: Custom Sub box
Thanks
the Glass took alot of patience , a heat gun and low heat for a long time till it starts to bend.
Old Jan 6, 2012
boyd117's Avatar
boyd117 is an unknown quantity at this point
Re: Custom Sub box
Great job man! Wondering is that a w3 or w7?
Old Jan 6, 2012
Re: Custom Sub box
Thank you The Sub is actually a 13TW5
Old Jan 6, 2012
boyd117's Avatar
Re: Custom Sub box
Talk about shallow mount! Looks like a wild sub...my buddy wants a shallow for his truck was going to suggest him the alpine type r, this however looks comparable.
Are you running it at the full 600 rms?
Old Jan 6, 2012
Kenny the Ricer
Re: Custom Sub box
The TW5's are badass, they put out a lot of power for such a shallow sub
And sorry, I'm an Alpine sub hater :P
JL Audio for life!
...Well, that's until I can afford a 12" FI BTL :P
Old Jan 7, 2012
Re: Custom Sub box
Thanks guys for the kind words.
well not just there considering the jl 500/1 but it has plenty of power.
I was a JL audio employee and i witnessed first hand the testing performed on their products.. I have been using their products since before i could drive.
I had an original 10w1 playing in my room. .I wont say there are not some other great products out there. But JL audio has never let me down. Take my 500/1 its been playing hard for 5 years without any problems.
As Kenny stated JL FOR LIFE!
I cant wait till they release this years products at CES . I think they are bringing out a 2000-2400 watt amp to power 2 W7s at once. and i know for a fact a new sub is being released.
Old Jan 7, 2012
drmcstford's Avatar
Civ ILL
drmcstford is an unknown quantity at this point
Re: Custom Sub box
Dude that looks absolutely amazing!Great job man !!!!
Old Jan 7, 2012
Kenny the Ricer
Re: Custom Sub box
I saw a couple of the teasers on JL's facebook fan page, looks goood
Once I find enough cash laying around, I'll prolly look into upping my W3v2 to a W6v2 with a slot ported box
I currently only have my 500/1v2 set at about ~300watts
Though my W3 can most likely handle it, it doesnt sound as good as the W6 in the lower notes
Just the foam around the speaker speaks for itself
Old Jan 7, 2012
RamAirDave's Avatar
RamAirDave is an unknown quantity at this point
Re: Custom Sub box
Amazing work man!! You have a talent for sure! Do you do installs for a living or just hobby?
Very impressed!
Old Jan 8, 2012
Re: Custom Sub box
Very impressed!
Thank you Dave. I used to install for a living now it is more of a hobby or select friends.
Here is a link to my friends S2000 i did very similar to mine . http://s1024.photobucket.com/albums/...%20on%20S2000/
And the other project in the works for a friend a 1980 Monte carlo restomodding http://s1024.photobucket.com/albums/...20my%20friend/
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
carid
Sep 28, 2015 10:13 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
