Windshield Washer Pump Replace
Old Dec 6, 2010
JRunyon21's Avatar
JRunyon21 is an unknown quantity at this point
It seems like every month there is something different that goes wrong. My windshield fluid pump is not working(At last I think that is the problem).
Reason 1:There is no whinning noise made when I try to use the washer fluid but the wipers work(That eliminates fuse and line plugage, right?). This leads me to believe my pump is bad.
Reason 2: I asked my dad to use some of his washerfluid from home and I've come to find out that he dilutes his. Slightly warmer temps so he must get by with doing this. I think the water expanded in my pump and broke it. I had no idea and I paid the price.
How can I gain access to the pump? I really do not want to take of the bumper(As I read i will likely have to). Any suggestions? If I do have to take the bumper off, is there a DIY for doing this.
As always, all help is greatly appreciated.
-Jason
Old Dec 6, 2010
Re: Windshield Washer Pump Replace
you can probably get to it by removing the driver side fender liner (the black plastic above the tire). and reach your hand in that way. i think most ppl take the bumper off because its complicated to change. you have to unplug the harness and slide the pump out carefully because there are lines attached to it and its sealed to the tank. i have a used 01-05 civic oem washer pump for $5 shipped sitting here if you want it. works perfectly, i just never used the washer system so i took it out a while ago. has hardly any use on it maybe 40 squirts.
Old Dec 6, 2010
JRunyon21's Avatar
If you can get it shipped out today I am all for it. I'll PM you.
Old Dec 6, 2010
yup i sent you invoice. i can ship asap once paypal is received.
Old Dec 6, 2010
lazlong's Avatar
...maybe 40 squirts.
Sorry, couldn't help it.
edit: What gearbox said, just take off the driver's side inner fender and it's right there, can't miss it.
Old Dec 6, 2010
hmm well guess he couldnt get back on to send money today. i have it sitting here waiting to ship. it should be easy, just yank the old one off and put the big hole in the tank and the little hole gets connected to the tube. i will include some extra tubing too if you need it. oh yeah and dont forget to plug the connector back in. and fill the tank before using. if you run it dry, the pump will fail pretty quick (my pump has never run when dry).
Old Dec 7, 2010
JRunyon21's Avatar
Thanks gearbox. I will let you know how things go.
-Jason
Old Dec 7, 2010
i should have it shipped out early this morning thanks
Old Dec 7, 2010
lazlong's Avatar
I'm a photo *****, what can I say.
Old Dec 10, 2010
JRunyon21's Avatar
Pump came in yesterday. I will be putting it in tomorrow. Should I just pull the old pump out and let all the fluid drain out? I will let you know how it goes. Thanks gearbox
Thanks lazlong. Should be an easy fix by looking at the pic.
-Jason
Old Dec 10, 2010
yeah the fluid you can catch and reuse if you have a pan to let it drain in. it should pull out and the new one pushes in. dont forget to remove and replace the hose on it. and the electrical connector. it can be a pain to get that one off and i forget how its clamped in. try not to break off the mounting tab.
Old Dec 11, 2010
JRunyon21's Avatar
Need help ASAP. I have no idea how to get those clips off under the wheel well to get access to the pump. I messed with them a lil but I think im gna break them. Im gna go and do my oil change and cpl other things. Hopefully I someone replies.
Old Dec 11, 2010
just pop the centers off with a flathead screwdriver on either side where there is an opening to stick it. then pull the whole thing out with both pieces together. if they are super old, you may break a couple. luckily a bulk pack is pretty cheap on ebay. if they are old you will have a heck of a time prying off just the center. be careful not to break the center round piece, otherwise it will be stuck and you have to use extreme force to pry the clip out and break it.
Old Dec 12, 2010
lazlong's Avatar
Yeah, if I'm gonna be taking any off I get a pack or 2 from Oreillys.
Old Dec 13, 2010
JRunyon21's Avatar
Figured the clips out by doing a little diggin in the forums. Broke about 3 clips. Ordered a lot of 20 for $5. Pump replacement went fine. Thanks for the help.
Old Jan 12, 2016
honda.lioness's Avatar
honda.lioness is a jewel in the roughhonda.lioness is a jewel in the roughhonda.lioness is a jewel in the rough
Can I get the reservoir out via the front driver's side wheelwell too? It is frozen and I want to thaw it and put in low temp fluid.
(It appears I stupidly added some fancy anti-bug debris windshield washer fluid to the reservoir this summer and did not think to check the freeze point. I no longer have a garage. It's going to be below freezing for several days. I have added some booster washer fluid that is supposed to bring the freezing point down to -20 F, but it won't go past the frozen fluid already in there. I may try high concentration rubbing alcohol and, if I can get my hands on a hair dryer, this too.)
Edit: Never mind. I warmed up some RainX Booster, added it, let it warm things, pumped out as much as I could with a $3 hand pump from Home Depot, and repeated until all the frozen fluid was gone and the lines were flushed. I added a 50/50 solution of RainX Booster.
Old Jan 12, 2016
At work I have a garden hose connected to a regular sink faucet, I turn on the hot water, stuff a long rubber hose as deep into the frozen washer tank as it will go, then squirt hot water right into it. Keep pushing the rubber hose in as the ice melts. I can thaw a completely full frozen tank in less than 10 minutes this way. Run the washer pump to empty the water then refill with good low temp fluid.
Easiest choice is to let it thaw on a day the temp is above freezing, then REMEMBER to actually run the washers til they quit squirting (tank emptied), then refill with low temp fluid. My problem is forgetting to do this while it's easy.
Old Jan 13, 2016
Good tip, ezone.
mattdoc
Mar 14, 2017 12:10 PM
shindrome
Exterior
May 5, 2015 02:50 PM
thesushiboy
Apr 12, 2015 02:54 AM
DaveyD
Mar 28, 2003 12:28 AM
KOPSEAL
Jan 1, 2002 03:23 PM
