Diy thermostat :s !!!!éé
Old Nov 7, 2010
a_a91's Avatar
a_a91 is an unknown quantity at this point
is there a DIY for a thermostat on an 04 civic on this forum, or does anyone know how... POST it up
Old Nov 7, 2010
Re: Diy thermostat :s !!!!éé
Drain coolant from radiator
remove thermostat housing
remove thermostat
replace with new thermostat
replace thermostat housing
fill radiator with coolant
bleed coolant system
take a nap
That's more or less it. I think I used my haynes manual as a guide when I did it. If you don't have one, you should grab one. It's a great guide to have.
Old Nov 7, 2010
Mad Dog Tannen's Avatar
^ Agreed. The first thing you should buy for any car is a service manual.
Old Nov 7, 2010
lazlong's Avatar
Thermostat DIY:
1. You can either drain the coolant or disconnect the lower radiator hose and put it to the side. You'll lose a cup or two of coolant but, not a lot.
2. Disconnect the connector:
3. Unbolt the housing bolt:
4. Unbolt the other housing bolt:
5. Remove and replace the thermostat (it only goes in one way).
6. Replace the bolts, the connector, and the hose.
7. Bleed the system.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Munzy
21
Oct 7, 2015 07:48 AM
david34
Sep 23, 2015 11:13 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
tooly145
Sep 5, 2015 01:05 AM
