Brake question
Old Nov 1, 2010
Brian1037's Avatar
Sedans > Coupes
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
Brake question
This has happened twice so far.
I'm just driving along, and as I'm slowing down with my foot on the brake, I hit a big and hard pot hole (very common on Quebec roads). The brakes will get "loose" (the pedal feels limp, as if it's not pushing back on my foot anymore) and make a loud sound. It's not screeching, but it's similar, almost as if air is gushing out of somewhere, but not really. It's weird. . I'll release the brakes and then it'll all be back to normal. Anyone know what's going on?
Old Nov 1, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: Brake question
Uhm.....stop going over potholes lol
Old Nov 2, 2010
TRIZ's Avatar
Re: Brake question
Brake line pressure? I dunno...
Its obviously the front breaks because the drums in the back dont do much for stopping you..
It might be possible that there is an issue with your line and when you hit the pot hole, your suspension compresses and the brake line travels with it, as it should, and puts stress (or relieves it) on your break line... Enh, dunno about that.
Check your break lines, and do a bleed... getting your head in the wheel well will tell you many times more then what this thread might be able to shoot out in guesses.
Old Nov 2, 2010
Brian1037's Avatar
Sedans > Coupes
Re: Brake question
Alright thanks. I was hoping this was a known problem with a name and all. When I have time I'll have a look under the car and see if I find anything, but I won't even know what to be looking for. I'll maybe take some pics and bump this thread whenever that time comes.
Thanks again
(And yes it's definitely from the front brakes)
And I forgot to mention that the car doesn't actually loose any braking power. Even though the pedal gets loose and the noise happens, the car is still braking like it was just before the pot hole. Next time it happens, I'll see what happens if I press harder on the brakes while the pedal is "loose"
Old Nov 2, 2010
jono237's Avatar
jono237 is an unknown quantity at this point
Re: Brake question
if your car has abs it could be the abs kickin in i know on gravel roads it does that for me will make a weird noise and the pedal feels useless just let go of the breaks and reapply. in my opinion the abs system has gotten me and a buddy of mine with a em2 in more trouble then good.
Old Nov 2, 2010
Brian1037's Avatar
Sedans > Coupes
Re: Brake question
I don't think it's the ABS. I accidentally activated the ABS on the first day I had the car when I was "testing" the brakes. It's very different from how the ABS works. There's no rapid engaging and disengaging of the brakes, and the ABS light never comes on or flashes (which I believe is should if the ABS activates).
Edit: Regardless, I'm going to try to replicate the situation and maybe make a video. MAYBE it's the ABS, but it's definitely not the ordinary ABS.
Old Nov 2, 2010
eastpureplaya's Avatar
eastpureplaya is an unknown quantity at this point
Re: Brake question
Thanks again
when looking under your car, check to see if it looks like any fluid has been leaking all over the place. If your brake line has a hole or anything like that it may spray the brake fluid and then the brake dust will build up on the fluid sprayed. If it looks like everything is okay, I would bleed the brakes because sometimes air in the line makes the brake feel looser then it should. I have never heard of this issue happening. I also live in a very bad area with a bunch of pot holes, NYC and northern New Jersey. Here it is basically unstoppable to hit pot holes. You sway from one hole into another. I haven't experienced this issue and i know I have gone into pot hole while braking also.
Old Nov 2, 2010
jono237's Avatar
Re: Brake question
in that case maybe i have the same problem as you and just thought it was abs boy that sucks ill definatly be following this thread to see what happens as i may need to do the same thing
Old Nov 2, 2010
shwoogie420's Avatar
shwoogie420 is an unknown quantity at this point
Re: Brake question
sounds like your abs.....and no the abs light does not come on when abs is activated.
Old Nov 2, 2010
Kenny the Ricer
Re: Brake question
ABS light only comes on when theres a problem with it
7thgensurvivor
38
Aug 29, 2015 11:50 AM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
