Catalytic Converter?
Old Oct 1, 2010
Hondaguy89's Avatar
Hondaguy89 is an unknown quantity at this point
Some time ago I realized my car does not have a catalytic converter, however it still has the stock exhaust. I am the second owner of the car. Does this provide more power? What is the point of having no cat?
Old Oct 1, 2010
Re: Catalytic Converter?
the cat itself is fairly restrictive if you look inside, like honeycomb mesh everywhere. still, they flow well enough on high hp cars. but yeah alot of people ditch the cat for a race header that is just an open pipe. bad for the environment tho. they prolly didnt have money to replace it with if the exhaust is still stock around it.
Old Oct 1, 2010
Hondaguy89's Avatar
So do I still have to stick with LX/DX exhaust components or can I get EX?
Old Oct 1, 2010
mbrishke's Avatar
mbrishke can only hope to improve
most likely yes, your still going to want to purchase lx exhaust parts.
UNLESS your stock exhaust is an ex conversion.But if both of your 02 sensors are still on the exhaust header, then it is not an ex conversion.
Old Oct 1, 2010
if you switch to EX exhaust, you have to replace EVERYTHING if yours is an LX. you need EX header, downpipe, cat, and catback exhaust (with muffler). if you are saying they just replaced the cat/header on your car with aftermarket (because cat is part of the header manifold), then all you need to go back to stock is an LX oem manifold with cat. if you want to convert to EX exhaust, you need all the ex parts including new manifold.
Old Oct 1, 2010
lowlife9's Avatar
is your car throwing any codes like p0420 ??? if not you could just have a universal cat converter welded on to your existing exhaust.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Luluharp
Sep 27, 2015 11:56 AM
pilebuck13
Sep 21, 2015 10:45 PM
Dsmak
Sep 10, 2015 08:30 PM
