My first car / civic please help :(
Old Sep 26, 2010
  #31
Re: My first car / civic please help :(
You don't need to get 55w.. I just said that's the most expensive version of the HID kit ddm has. Get a 35w 5000k and you'll be fine.
And retrofitting is more or less that: replacing the halogen projector with one designed for HID lighting. Alternatively, it can be installing an HID projector in a headlight housing that never had a projector to begin with (i.e. your stock reflector headlight housing)
http://www.fitfreak.net/forums/fit-i...-retrofit.html
there's a great example of retrofitting the morimoto mini into a reflector housing. I only know that thread because I want to attempt that retrofit into my sister's 2010 honda fit. It also gives you an idea of the great light output it provides, and if you scroll down (post 38), it shows you the bi-xenon feature of the morimoto mini (flipping the high beam activates a solenoid to drop the shield, providing the higher beam cutoff for your high beams)
edit: if you're really worried about legality, find OEM HID components, or just buy the kit from theretrofitsource
http://www.theretrofitsource.com/pro...315e53336bb7a0
They'll give you 4300k bulbs, which is OEM color temperature. With that kit, you get a set of ballasts, bulbs, shrouds, projectors, and even a wire harness for your OEM H4 plug. All for $300. $350 if you opt for Philips bulbs and ballasts with longer wires. $375 if you want the previous 2 options AND angel eyes.
Old Sep 26, 2010
  #32
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
Thanks for all ur help, it really means a lot and i'm learning so much (+1 Rep)
But what is Bi-Xenon??
And if i buy that kit with the angel eyes what sort of headlight housing would i need to buy?
And just as a side question, are CCFL headlights good? I read somewhere that they burn out fast and aren't as good as LED's
Old Sep 26, 2010
  #33
Old Sep 26, 2010
  #34
Okay lol now what about the CCFL's vs. LED's?
Old Sep 26, 2010
  #35
My CCFLs haven't burned out yet..
Post 5 has pics of 'em
https://www.civicforums.com/forums/1...-new-hids.html
And some video to show you what they look like.. kinda.. even though they're not the main point of the video. The CCFL is what surrounds my projector.
http://www.youtube.com/watch?v=2PijOlCLqEc
Old Sep 26, 2010
  #36
Okay i'm good to go then
If i buy a blackened version of my stock headlights will they fit in them, or do i need like a special headlight?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
Markias
Detailing
Nov 4, 2001 05:15 PM
