Hondas come de-tuned?
Old Aug 3, 2010
Mr.VTEC's Avatar
Mr.VTEC has a spectacular aura aboutMr.VTEC has a spectacular aura about
I've heard that Hondas come de-tunned from the factory.......idk if this is true. If it is could I go to a performance shop and have them tune it?
Also....does anyone make programers for the 7th gen?
Old Aug 3, 2010
02civicsi02's Avatar
Low and slow!
Re: Hondas come de-tuned?
No. And there are alot of different ones but kpro is the best. And ya you can run kpro off your d17.
Edit: The stock ecus are tuned for the cars normal settings and daily driving and it cannot be changed. If you want to tune your car then go get a new management.
Old Aug 3, 2010
they are a bit on the rich side yes. so you could lean it out for more power and better mpg. its tuned for the average person on the side of safety.
Old Aug 3, 2010
Mr.VTEC's Avatar
Do either of you know where I could find this kpro?
Old Aug 3, 2010
Mr.VTEC's Avatar
Ok so I went to HONDATA and they have the KRPO and CAm gear set up...but then I still need to get the donor ECU. I went on EBAY and found donor ECUs with the KPRO already linked to it. So then I would just need the cam gear and windows program right? Also the donor ECU with the KPRO linked to it will plug to in to my D17 right?
Old Aug 3, 2010
lazlong's Avatar
Most cars these days come de-tuned otherwise they wouldn't be able to meet fuel mileage standards , emissions standards, blah, blah, blah
Old Aug 3, 2010
Low and slow!
You never know with ebay they could cheat you or something. Though yes you have to either give them your ecu or find another and send it in to hondata and they do there little thing and send it back to you. Kpro is the best to have cause of the fact that it runs off your stock ecu it just has been upgraded big time. You can tune it and leave it unless you change the boost or cams or stuff like that. I know other ecus if the weather is different the next day you have to re tune it. And yes it will run with your motor.
Old Aug 4, 2010
Mr.VTEC's Avatar
Can I send my D17 ECU to them....or does it have to be a K series ecu?
Old Aug 4, 2010
ronaldo9's Avatar
Must be K Series.
Old Aug 4, 2010
Low and slow!
Must be a k ecu .
Jessica Leung
May 5, 2015 05:12 PM
carid
Apr 30, 2015 07:00 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
