Overheating ?
Old May 25, 2010
civcspool's Avatar
civcspool will become famous soon enoughcivcspool will become famous soon enough
Overheating ?
Ok I have a 2002 lx civic need some advice here..
My problem is whenever I drive and hit the traffic my car's temp starts to go up and as soon as I start moving my temp goes down. BUT, my main concern is when I turn my a/c on and hit the traffic nothing happens temps stay where it is doesnt go up or anything. I also checked and both fans are working, so what could it be ? I haven't changed my water pump and I dont know when is it due because I changed my tach and forgot to mark my tach.
could it be a bad water pump? thermostat or fan ? headgasket(I dont see any signs of white smoke or anything my coolant are upto par no changes or anything)?
Old May 25, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Overheating ?
Hmmm....
Start with the simple and cheap stuff.
If you haven't already change your thermostat, rad cap. Then bleed the system really good. If the problem persists then you can look into other things. If you had a blown head gasket your coolant reservoir container would probably be overflowing and your coolant level would be low. How many miles on the car? Water pump is such a pain in the *** because it's timing belt driven.
Old May 25, 2010
Re: Overheating ?
^^ What he said.
Old May 26, 2010
civcspool's Avatar
Re: Overheating ?
Ok I found out the problem my fan doesnt work .. it only works when I turn on my a/c thats why its not overheating when my a/c is is there a switch for it or a relay to turn it on ? where is it located?
Old May 26, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: Overheating ?
Unplug the fan switch (see below) and short the 2P connector with a jumper wire. If the fan now runs with the key in ON(II), then replace the switch.
Old May 30, 2010
PurpCivic's Avatar
PurpCivic is an unknown quantity at this point
Re: Overheating ?
It's right on the thermometer. But those were my signs first but mine got worst as u see on my thread
Old May 31, 2010
ExistEvolution's Avatar
ExistEvolution is on a distinguished road
Re: Overheating ?
^^What he said, lol
Old May 31, 2010
Re: Overheating ?
Originally Posted by ExistEvolution
^^What he said, lol
lol, post *****
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
tooly145
Sep 5, 2015 01:05 AM
