2002 Civic LX change timing belt. TOD at number 1 piston
Old Feb 2, 2010
llinj9's Avatar
llinj9 is an unknown quantity at this point
Hi. Dear Honda Owner:
I want to change my 2002 LX civic timing belt. Before I start I want to get everything clear. My question is: suppose that I get the timing belt off and I totally disturbed the timing relation between crankshaft and camshaft, how do I set up the TDC for number 1 piston on the compression stroke.
I had read the timing belt change from this url and still have the above question
http://www.7thgenhonda.com/forum/showthread.php?t=5796
I also have Haynes Repair Manual and I read it as well
I am asking this question because if the timing is messed up, it might get the valve and piston damaged and it will cost thousands.
Thanks for the help.
Dan
Old Feb 16, 2010
CoupedUp04's Avatar
CoupedUp04 is an unknown quantity at this point
Re: 2002 Civic LX change timing belt. TOD at number 1 piston
If you take a couple hundred dollars and the car to a mechanic they'll tell you the answer to that question and do it for you
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
jonavin
73
Oct 4, 2004 07:18 PM
Lightman
15
Nov 8, 2001 05:06 PM
