electric load detector
Old Jan 23, 2010
dspeedcrazy02's Avatar
dspeedcrazy02 is an unknown quantity at this point
my alternator went out and i replaced it with a new one,arfter all instaled.the check engine light and the battery light was on.so i got it tested and the charge system and battery were all good.the check engine light read out that both o2 sensors went out and the electric load detector high voltage came up.all the fuses are good too.what do i check next.
Old Jan 23, 2010
Re: electric load detector
replace the ELD (which usually means replacing the fuse box since its integrated with it).
Old Jan 23, 2010
thanx, ill get back after i do that.
Old Jan 29, 2010
ok,so i replaced the eld.and the same thing is happening.i still need to replace the 02 sensors,but the battery light is still on and the detector code is still on.
Old Jan 29, 2010
how much voltage is the alternator putting out? im wondering if the place that tested didnt know how to do it. cause it sounds like it may be putting out too much voltage like over the normal 14.2v
but get the o2 sensors changed anyway if it needs it.
Old Jan 30, 2010
i got it tested by 3 diffeent places... and everything was good..alternater was putting out normal voltage..um..batterie is fine..and starter is fine....
runawaykinms
15
Mar 22, 2019 10:32 AM
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
Bruce2
Sep 27, 2015 08:45 PM
JMKendrick
Sep 16, 2015 06:17 PM
