i need help....asap
i need help....asap
I have a 01 ex with tein ss coil overs .......but I'm kinda getting tired of them the car is way low and its mad stiff........I'm thinking about putting the stock suspension back on......but not so sure......does anyone kno of another type of suspension that is smooth .....
Re: i need help....asap
how about adjust the ones you have? i thought you can soften the damping rate, and also play with the height. those are fully adjustable.
They are fully adjustable. Slow down/soften up the rebound on them, they will ride more like the stock suspension, you dont need to have it hella stiff so everytime you hit a crack in the road your cd skips.
this is the main website http://www.progressauto.com/ but you can get them cheaper elsewhere like www.corsportusa.com search around. you can also have the damper and spring rate customized to your liking.
also make sure you are running the honda recommended 30psi in the tires. even a few psi higher will make the ride very stiff. i used to run 35 but it just rides too rough. at 30 its perfect and almost feels like the oem suspension again.
I would go by what the tire says, and at least inflate to the min. You dont wanna be on 30psi, hit a pot hole and ruin a rim.
