trunk lever broke?
Old Dec 20, 2009
2005civiclx's Avatar
2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough
trunk lever broke?
ok so my gas/trunk lever only works for gas now. i can only push it down and i cant pull it up to unlock my trunk so i have to unlock my trunk with my key everytime and its getting annoying but idk whats wrong. the trunk isnt locked from the inside. i checked and ive tried locking it and unlocking it to see if that was the problem. but im just wondering what could it possibly be.
Old Dec 20, 2009
04 Honda Civic's Avatar
Re: trunk lever broke?
Check out the cable make sure its not getting stuck, or not attached at all. Does the handle feel loose or hard to pull?
Old Dec 20, 2009
its actually really hard to pull. feels like its locked but its unlocked. so maybe the cable is stuck.
Old Dec 20, 2009
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Cable is stuck. Check the trunk latch and make sure it is moving.
Old Dec 20, 2009
have someone pull the lever while you watch the trunk latch (with the trunk open). see if the cable is doing anything, and if its attached properly. do you have aftermarket alarm? if you do, its prolly worth buying the 2001 accord motorized trunk latch popper and put that in. then you wont have to worry about the cable.
Old Dec 20, 2009
CoupedUp04's Avatar
CoupedUp04 is an unknown quantity at this point
I had the same problem. The key wasn't turning the unlocking mechanism inside the car. That little cover over the lock inside the car pops on and off. Take it off and see if the key is actually doing anything and you may have to use a tool to turn it manually. If it's not the cable then check that. Its really easy, and you can just snap the cover back on when you're done.
Old Dec 20, 2009
the cable seemed to be working right i checked it in the trunk and it wasnt stuck so im sure it is the locking mechanism ill check that out tomorrow.
thanks for the advice everybody
Old Dec 20, 2009
oh and gearbox no i dont have an aftermarket alarm. i need to get one though cause my car has gotten broken into before and no alarm went off and i also dont have a panic alarm anymore. for some reason that has never worked. dont know why but it doesnt bother me too much
Old Dec 21, 2009
lowlife9's Avatar
maybe this will help .
http://www.fueldoorfix.com/
Old Dec 21, 2009
CraigW's Avatar
fdf would not effect the trunks operation.
You can gently and evenly pry the lock cylinder straight up and it will come out. You can work the lock/unlock mech down inside manually to see if it makes any change.
Do you still get the click feel/noise when using the key to lock ??
Old Dec 21, 2009
it was the lock it was stuck on lock. so i just had to turn it on the inside to unlock so its fixed now.
Old Dec 22, 2009
lol thats funny I was going to say make sure its not locked but didnt honestly think you didnt check that already lmao.
Old Dec 22, 2009
i did check that but i never popped off the cover to see if the locking pin was actually moving and it was stuck on lock but the key still turned the lock from lock to unlock easily but the pin wasnt moving with the lock anymore. so i had to pop off the cover and take a screwdriver and manually turn it from lock to unlock without the key
solarpunk70
Apr 12, 2016 11:43 AM
Crazygrlinak
Oct 8, 2015 05:06 PM
Munzy
21
Oct 7, 2015 07:48 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
