Aftermarket Muffler
Old Nov 7, 2009
mattmac10's Avatar
mattmac10 is an unknown quantity at this point
Aftermarket Muffler
Hey i was just wondering what size muffler should i get if i was to get just a muffler ?
Old Nov 7, 2009
unTuned's Avatar
Re: Aftermarket Muffler
if youre just cutting your old muffler on and welding or clamping a new one on, dont use a muffler any bigger than a 3.5" tip. why are you doing that? catback systems are cheap and they replace your entire piping and everything. your stock piping is only 1.75" and just putting a muffler on that will sound like ****.
Old Nov 8, 2009
mattmac10's Avatar
yea i know a cat-back would be better , but i wasnt looking to spend like 500 on exhaust .Thats why i was considering just a muffler . What cat-back system would you recommend?
Old Nov 8, 2009
508bmartin's Avatar
508bmartin is an unknown quantity at this point
magnaflow is around 500 and its not an annoying exhaust..
Old Nov 8, 2009
turbo zombie's Avatar
turbo zombie is an unknown quantity at this point
you can get on jegs online and get fairly cheap universal mufflers, like under $100. at least in my area, most exhaust shops can do a custom cat back with a muffler you provide for under $300, if not cheaper. if you still want to do just the muffler, i'm sure that would def be even less.
Old Nov 8, 2009
unTuned's Avatar
i would also recommend that. do 1 of two things
a) remove your entire stock exhaust and get the shop who is welding your new muffler on to do some new piping for you so you have a full system thats bigger than the stock 1 3/4" piping.
b) get a full bolt on catback system
the advantage to option a is that if you ever want to remove it, you can do that and put your full stock exhaust system back on if you ever have a problem. if you cut your stock muffler off, and put a new muffler on, it might be annoying later on down the road to cut the aftermarket muffler off to weld the stock muffler back on. dunno its up to you.
Old Nov 9, 2009
as far as pipe sizing goes, i ganked this off of motoiq.com.
"Pipe Diameter Guidelines
Some basic exhaust pipe diameter guidelines for stock or bolt on modifcations, non-turbo cars are as follows:
1500cc-2000cc motors- 2 inch
2100cc-2500cc motors- 2.25 inch
2600cc-3000cc motors- 2.5 inch
Add ¼ inch to the pipe diameter to optimize for [nitrous] use. [Nitrous] increases exhaust gas volume. Remember that this may be too big for optimal operation off of the bottle. For turbo motors 3 inch is the minimum size pipe that you would want to run, even for the smaller motors. For turbo motors larger than 2.5 liters, the biggest tubing (usually 3.5 inch) that you can find is appropriate. It is almost impossible to have too big of an exhaust on a turbo car."
On my NA volvos i ran 2.5", and they were 2.3 liter motors. i wouldn't go more than 2.25" on our cars without a turbo.
Old Nov 9, 2009
lowlife9's Avatar
if your going to get just a universal muffler i would recommend a OBX twin loop. http://www.2kracing.com/Product/18298.html
Old Nov 9, 2009
Keepitmovin's Avatar
Keepitmovin is an unknown quantity at this point
Just find urself an axle back, it's the rear section so it bolts right on -you can do it yourself and you can find em for around $150. Here's mine- yea yea wash my car.
Name:	Vibrant at angle.jpg
ID:	77541   Click image for larger version
Name:	Vibrant street power axleback.jpg
jdawgzcivic
17
Feb 1, 2020 04:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
bhollie
Sep 22, 2015 11:08 PM
yyyktk1
Sep 12, 2015 04:02 PM
