Need Help please
Old Sep 18, 2009
03civiclxcoupe's Avatar
03civiclxcoupe is an unknown quantity at this point
Need Help please
does anyone know where the fuse is on this or how can i fix this?...never done this before..thanks.
[IMG][/IMG]
Old Sep 18, 2009
lowlife9's Avatar
Re: Need Help please
my car does the same thing i wasn't sure if it was suppose to look like that or if the lights were burned out. i have a VP 04.
Old Sep 18, 2009
unTuned's Avatar
if those two lights are out, i dont think its a fuse. if a fuse was out, i think all of them would not work but it looks like you still have one working.
my defrost light (the one you have on in the picture) went out one day when i was installing a stereo and it was out for a couple weeks. i gave it a good smack with my hand one night and it started working again and has been good ever since.
try giving it a good smack first to see if it helps, it did for me. otherwise you will have to remove your climate control unit to investigate more closely. you would do that the same way you would start installing a stereo. have you ever done that?
Old Sep 19, 2009
lol...i have installed a stereo long time ago and it never done that till 2 weeks ago
Old Sep 19, 2009
CraigW's Avatar
It's the bulb. 1 bulb lights both switches.
Old Sep 19, 2009
unTuned's Avatar
yea that would make sense. the recirculate air + a/c buttons use one light, and the defrost uses another light. i had the defrost light go out so only the defrost didnt work. it looks like its your other bulb. if they are regular bulbs and not leds, they are very easy to change and i found it at the local auto value store. i changed the one underneath my temperature gauge a few days ago and it took me less than 5 minutes.
Old Sep 19, 2009
ok..sweet! thanks guys
Old Sep 21, 2009
Staninator's Avatar
Staninator is an unknown quantity at this point
me defrost one is burnt out. I learned to live with it haha. Don't even waste your time.
Old Sep 21, 2009
GreenMachineDX's Avatar
GreenMachineDX is an unknown quantity at this point
Yea, I mean if u going to fix that, If It Was Me I Would Do The LED Conversion, since u are taking the whole dash board apart. Its Just Me Tho..
Old Sep 21, 2009
so yeah i gave it a good smack and it went on lol...but when the light bulb goes off ill replace it....thanks.
Old Sep 21, 2009
i would love to do the LED conversion but i dont know how to do that..and i dont know how much it would cost for me to do it.
Old Sep 21, 2009
I think u can keep it under 50 bucks.. Ebay..
Old Sep 21, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
Just look it up. They have LED bulbs that you can get. Look for the DYI topics
Old Sep 21, 2009
ok sweet thanks yall!
Old Sep 21, 2009
i just did custom leds, maybe cost $15 for the pack of 50 leds. i used 5 for each dial, and two for each button in orange (not amber). then used resistors to dim it down to a normal brightness and match the dials and buttons. there is quite alot of room inside the dials, but buttons you have to stuff them inside. ofcourse all the factory colored plastic films will need to be removed before you do any color changing with leds.
and put some led backlight for the gauges to match the orange color
Old Sep 22, 2009
lowlife9's Avatar
i tried bitch smackin mine and a didn't work.
