Clutch Times
Old Aug 6, 2009
cmy_civic's Avatar
cmy_civic is an unknown quantity at this point
Clutch Times
Well, the civic is around the corner from a clutch job. I was wondering how long the average job takes to finish. Ive never done a clutch job on a civic, but ive done some work on my bimmer. Everyone says its a ton easier, so I think I should be ok.
Can some of you guys gimme some times please, thx.
Old Aug 6, 2009
speedfoos's Avatar
Re: Clutch Times
Give yourself about 6 hours to do the job, less if you pull the motor.
Old Aug 6, 2009
cmy_civic's Avatar
Re: Clutch Times
Hmm, ok. And since I would have to take out the main axle, if I order a new one (only pax side needs to be replaced) would I just need to slip it back in?
Old Aug 7, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Clutch Times
The axles literally just snap in and out once they are unbolted. You have to take them out to replace the clutch anyway. If you need a new just put the new one in after you are done with the clutch.
Old Aug 7, 2009
cmy_civic's Avatar
Re: Clutch Times
Ok cool. We need to replace the clutch soon so the axle is going to be at the same time then. Thx
crowtoo
May 11, 2015 06:50 PM
usajags84
May 10, 2015 08:11 AM
oqjoi
Transmission
May 6, 2015 06:27 PM
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
