breather filter .
Old Jun 27, 2009
lowlife9's Avatar
breather filter .
i just bought a breather filter for my valve cover what should i plug the SRI with any ideas ???
Old Jun 27, 2009
TRIZ's Avatar
Re: breather filter .
Anything that wont get sucked in there. You could pick up some of that plastidip and do several dunks to make a plastic cap for it
Old Jun 27, 2009
unTuned's Avatar
i was actually just thinking about the same thing last night.
when i ordered my intake the hose they gave me wasnt long enough so no matter how tight i have it clamped, sometimes it slides off the valve cover side. i was thinking just to get a breather filter for the valve cover side and capping the intake hole as well.
what i was thinking was just going to the store and buying one of those little syringes of all purpose epoxy. you just squeeze it out and when it mixes together it becomes very very thick, almost like gum. you put it where you need and within a few minutes its set, and in a couple hours its dry as steel. its definitely a permanent fix so if you want to do that, it would be a bitch to ever get off. the more i think about it the more id want to avoid it.
the best idea is just to probably find a thick piece of rubber, maybe even one of those rubber bouncy *****, and just keep cutting chunks off of it until you make it into a mushroom shape and squeeze it in there, that way you can make it fit as tight as you want it to, and by making it a mushroom shape, it will never get sucked in either.
Old Jun 27, 2009
V84Lunch's Avatar
V84Lunch has a spectacular aura aboutV84Lunch has a spectacular aura about
Right on Triz, Plastidip or something similar for the win - definately a nice and clean 'easy fix'
Old Jun 27, 2009
lowlife9's Avatar
i was going to try to find a small rubber table leg peice to slide over it maybe clamp it if i have to i don't really care qbout looks.
Old Jun 28, 2009
unTuned's Avatar
yeah it really wont matter, so long as its sealed and not able to get sucked in. i was also thinking one of those flat square thin pieces of rubber patch that you patch a bicycle tire with. you could just put it over it and put a small ring clamp over it. theyre pretty thick and durable but still really small.
Old Jun 28, 2009
lowlife9's Avatar
for now i used a peice of the old tube and wedged a peice of wood at one end and clamped it till i find a more permanent salution.
Old Jun 28, 2009
well breather filter is a bad idea. you need the vacuum for the pcv valve to work properly and keep corrosive gases out of the engine. breather filter does not just cause more pollution, it will slowly destroy your engine.
Old Jun 28, 2009
unTuned's Avatar
so in other words its better to have the vacuum of your intake suck the gasses out and spit them into the throttlebody? wouldnt that be worse then just letting them out of the system with a breather filter?
or do you actually need a vacuum to release the gasses?
Old Jun 29, 2009
pcv works off vacuum, so essentially with a breather filter, its like deleting the pcv system completely.
Old Jun 30, 2009
unTuned's Avatar
hmm well thats good to know. i was going to plug my intake and put a breather filter since the hose they sent me was a bit too short, it sometimes slides off and i have to reclamp it. i was thinking it just vents on its own out of the chamber. i never even thought it needs vacuum to work. in that case i wont touch it.
Old Jun 30, 2009
lowlife9's Avatar
i just picked up some tubeing from napa one foot for $1.50 so whatever you got for auto stores in canada bring in that crappy short tube and get that diameter .
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Cam Diaz
Sep 29, 2015 07:17 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
NaturalSelectio
Sep 6, 2015 06:59 PM
