ground wire help ??????????
Old Jun 18, 2009
lowlife9's Avatar
i noticed when upgrading my wires that the stock negative ground goes from the battery to the chassis and then to the transmission . do i need to follow this path or can i ground it just to the transmission . im asking because the wire kit i bought is one piece.. also can i go from the battery to the transmission and then to the chassis in that order does it make any difference .
Old Jun 18, 2009
Re: ground wire help ??????????
it doesnt matter, so long as you ground each stock location. trans ground is basically for the starter to function since its ground bolt is connected to the trans.
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
