turbo build
Old Jun 9, 2009
jblz007500's Avatar
jblz007500 is an unknown quantity at this point
turbo build
alright, im new here and figured it would be the best place to ask. i have a spare d17 for my 02 ex, i'm gonna go turbo but cant find anywhere to buy the internals. im not lookin to go super crazy on power, would like to stay around 250hp, ive seen on other sites where people claim more but they dont list what parts they are runnin. not intrested in a k20 swap. thanks
Old Jun 9, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: turbo build
www.dezod.com
Old Jun 9, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: turbo build
Well, for 250 hp, you should either lower your goals and stick with a stock block or raise your goals and go ahead with the built block. A built block is good for 300 easily if not more. 200 hp is not too lofty of a goal on a stock motor, possibly 250 with some head work.
Old Jun 9, 2009
speedfoos's Avatar
Re: turbo build
250whp and kpro is easy, just replace the stock rod bolts with ARPs.
7GH being down FTL....
Old Jun 9, 2009
BJanzen's Avatar
Re: turbo build
Haha I was wondering about that...
Old Jun 9, 2009
twin's Avatar
twin is an unknown quantity at this point
Re: turbo build
the best place to get the internals are from dezod.com they sele good quality parts. if your are looking for 250 at the crank, you are defenitly need to invest on your motor or lower your current goal if you want a good reliable engine. if my calculation are right in order to achive 250 at the crank you need higher than 10 psi of boost and with a compretion ratio of 9.5 it would be a bad idea. i suggest to invest in some wiseco piston that would lower the conpretion ratio of the car and then ensure it with ARPs stods.
Old Jun 10, 2009
baron340's Avatar
Re: turbo build
Have you ever done a turbo build? 250 is perfectly attainable without tearing too far into the motor. The stock bottom end will be fine for 250 pending it is in good health before boost. The stock cam however seems to run out at about 225 hp. A cam, ARP headstuds and rod bolts along with k-pro should be more than capable of 250 hp.
Old Jun 10, 2009
speedfoos's Avatar
Re: turbo build
^^ Jonathan speaks the truth.
FYI... I ran 260 to the wheels on a stock bottom-end, PnP head, Stage 2 Crower cam and a piggyback.
Old Jun 10, 2009
daragez's Avatar
daragez is an unknown quantity at this point
Re: turbo build
Originally Posted by BJanzen
nice link!....
Old Jun 10, 2009
twin's Avatar
Re: turbo build
yea you may be right and i do have one runing 8 psi of boost i guess i like to be cautious when it comes to the amount of boost, i dont have the money nor the time to be fixing my motor. then again by the look of things i guess is only me.
Old Jun 10, 2009
jblz007500's Avatar
Re: turbo build
well i checked out dezod and am probally gonna run the cower stage 2 cam def, arps are a must and the k-pro.and if you say the block can handle the boost i'll probally just pick up a set of pistons and have the head worked on. thanks guys i'll keep you posted..
Old Jun 11, 2009
baron340's Avatar
Re: turbo build
The stock block can handle it... IF it is in good condition to start with, and there is nothing wrong with playing it safe. Do a compression and leak down test, if everything checks out, boost away.
Old Jun 11, 2009
exturbo6's Avatar
Re: turbo build
if you end up buying the stage 2 cam. i have a set of supertech valve springs and retainers. used, with less then 4k miles on them. id like 150+shipping. if your interested, send me a pm ill get you pictures.
Old Jun 11, 2009
BJanzen's Avatar
Re: turbo build
If you do a stage two cam you WILL need the springs and retainers.
Old Jun 11, 2009
exturbo6's Avatar
Re: turbo build
that is why i offered him.
Old Jun 11, 2009
jblz007500's Avatar
Re: turbo build
hey i appreicate the help, but i have a fear of used parts, i got screwed over when i did my prelude 2 ys ago dude sold me a worked up h22 with a cracked head and loose crank, i wanted to kill him
HondaGuy7
Feb 22, 2016 01:00 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
