2002 civic ex guage reading
i got a friend whos guage stop working by this i mean dat the speedometer and fuel line reading stop working can someone plez tell me wat he has to do to get them to work again i figure it mite be some wiring promble behind the cluster but i could be wrong
Re: 2002 civic ex guage reading
Make sure all the connections in the back of the cluster are solid and check all the fuses. Other than those, the cluster is probably just dead. And on a related note, and a shameless plug, I have one sitting in my garage from an 01.
The gauges have a self diagnostic function
check fuse #9 in underhood fuse box and #10 in under dash fuse box.
1. push and hold trip reset button
2. turn the lighting switch on
3. turn the ignition switch ON (do not start engine)
4. within 5 seconds, turn the lighting switch off, then on and off again.
5. within another 5 seconds, release the trip meter button, then push and release the button 4 times repeatedly.
notes: diagnostic mode ends when ignition is switched off or vehicle speed exceeds 1mph.
all gauge needles should make a full sweep from min to max and back again. beeper sounds 5x, indicator lights flash, segment display flashes 5x. pressing the trip meter will restart needle sweep.
credit goes to gearbox
credit goes to tinman actually. i didnt come up with that lol. but if it doesnt work in diagnostic mode, theres a problem and you need a new cluster. ebay has ton of em.
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
