Triple Pillar gauge installation
I am looking for a DIY on an install for up to 3 gauges in the pillar. whatever they may be...voltage, oil pressure, water temp...what do these gauges hook up to or need to be hooked up to for them to read?
I'm real good w/ working on my car so even just a general idea would be better than nothing.
Thanks in advance for anyone who has some info or experience in doing this.
Re: Triple Pillar gauge installation
Since every company makes their sensors differently, each one needs to run off the exact sensor the gauges came with. Like if you have an oil temp or pressure gauge, some companies make a oil filter sandwich that get placed between the oil filter and the engine block for easy access. after you place the sensors on, you run the line, or if it's electronic the wire, back to the gauge and apply the other required sources, Constant, ACC, ground and it should work.
Every gauge requires different things to be monitored so if you have an exact list, I can be of more assistance.
