help with noises after strut install...
Old Mar 7, 2009
ahailey's Avatar
ahailey will become famous soon enough
i installed my new struts and springs tonight (tokico blues & neuspeed sports), in only didi the fronts then it got too dark, but anyways, when i turn my wheel it makes loud noises like something is loose? all the bolts are tight, but it only makes the noises when turn while i'm stopped or if i'm turning while going slow. any ideas? thanks.
Old Mar 7, 2009
IRPancake's Avatar
IRPancake is an unknown quantity at this point
Re: help with noises after strut install...
Was the spring seated correctly on the strut perch?
Old Mar 7, 2009
ahailey's Avatar
as far as i know, i've never put springs on before, i just used the DIY on this site, but **** i don't want to pull it all back apart that wore me out.
Old Mar 7, 2009
IRPancake's Avatar
well, take a break or a day or 2 and do it agian. you shouldn't need to completely undo it, just pop the wheel off and if you can see where the spring and perch meet, there should be a spiral kind of indent in it, and thats where the end of the spring goes.
When I reassembled the struts on my car (mz3) I had the same thing happen, and I had to redo the one side because I put it in wrong. Not a huge deal if thats what it is. It could be something else though but thats my .02
Old Mar 7, 2009
ahailey's Avatar
i put the end of the spring on the bottom right up against the spot where it's supposed to stop and i put the top into the same indention that the stock spring left, hell i might just take it to a shop and tell them to figure it out.
Old Mar 7, 2009
ahailey's Avatar
it won't hurt it to drive around with it like this for a few days will it?
Old Mar 7, 2009
IRPancake's Avatar
depends on what it is. mine just creaked alot for a few days, but nothing bad happened, definately dont drive hard. Were there any washers you were supposed to install?
Old Mar 7, 2009
lowlife9's Avatar
did you line up the top hat with the arrows if not there not in correctly
Old Mar 7, 2009
ahailey's Avatar
yea i made sure they were lined up like in the DIY
Old Mar 8, 2009
BigVic4545's Avatar
BigVic4545 is an unknown quantity at this point
I have the same noise on my front springs....when i turn the wheel...sounds like a popping noise....but i never checked it out....i been driving like that for 6 months now and havent had any problems. But im pretty sure that it has something to do with lining up those stupid arrows
Old Mar 12, 2009
ahailey's Avatar
so if i didn't mark it when i took it apart...how do i tell where to try to line them back up when i take it back apart? or do i have to play with it until i get it right
Old Mar 12, 2009
BigVic4545's Avatar
I actually stopped being lazy and checked the noise out on my car... When i turned the wheel my springs were rubbing against the plastic cover under the fender. so what i did was cut a big chunk of that plastic off so that it wont rub with the springs....wow after 6 months i finnaly figured it out. BUT i also remember that when i DIY my springs i accidentally messed up one the lca joints...therefore there still remains a slight popping noise...which is from the lca joint.....but it is not as loud anymore because springs arent rubbing against that plastic cover anymore... make sure you DOUBLE check your lca joints....look for any grease leaking from the boot.
Sep 26, 2023 06:44 PM
honda.lioness
16
Feb 10, 2017 10:53 PM
Amulon
Aug 18, 2015 11:03 AM
Strycker
Aug 2, 2015 08:40 PM
mHo2
Jul 27, 2015 12:57 PM
