Amsoil transmission oil
Old Mar 6, 2009
IRPancake's Avatar
IRPancake is an unknown quantity at this point
Hi all. You guys were very helpful with the transmission questions I asked regarding removing it. I have one final question and I'll be out of your hair . I've read a few conflicting things, and I've spent about an hour searching so far. Remember this is my dads daily driver, we're putting a fresh transmission in it.
From the search, I know I dont want to use 10w30 unless an emergency. Other people recommend Redline MTL, which is a 70w-80 I believe. I have not had good experiences with redline and would like to go another route. A place nearby sells Amsoil, which I personally like, but they have 2 different oils that are close to both of the other suggested oils.
Basically, should I get the 5w-30 synchromesh, or the Manual Transmission & Transaxle Gear Lube 75W-90?
Thanks again
Old Mar 6, 2009
lordhelmet's Avatar
Re: Amsoil transmission oil
Why don't you go OEM Honda trans fluid?
Old Mar 6, 2009
IRPancake's Avatar
These transmissions seem to have issues, and I dont want to point fingers at the fluid (or lack of keeping up with mainteance), and I'm sure oil from a honda dealer is probably more expensive than amsoil anyways. I've personally used it in my BMW's tranny and it made a huge difference. Whatever we go with, I'm going to recommend we flush it more often to lessen the chance of it happening again.
Which weight is recommended, the 5-30, or 75w-90?
Old Mar 7, 2009
IRPancake's Avatar
dont mean to be a pain but we're doing it tomorrow and I'd like to get the oil before then. thanks.
Old Mar 7, 2009
Alpha 5's Avatar
I ran a NON OEM Trans fluid in my auto once. It resulted in me going to Honda to get a tranny flush 2 weeks later. I suggest OEM Honda Fluid Nothing else. It is not expensive and you will have the piece of mind knowing you have the Propper fluid in the trans.
Old Mar 7, 2009
IRPancake's Avatar
I went with the 5w-30 amsoil
APPLICATIONS
Recommended for automotive and light truck applications that require synchromesh transmission fluid. Applications include manual transmissions and transaxles such as New Venture NV T350, NV 1500, NV 2550, NV 3500, NV 3550, NV 5600, and Tremec T4, T5, T18, T56, T176, TKO500, TKO600, TR 3450 and TR 3550. Replaces MTF-94 fluid for Land Rover, MG, and Mini Cooper. Replaces Honda Genuine MTF fluid for manual transaxles and Texaco MTX fluid. Not for use in engines or wet clutch applications.
RIPSAW
Nov 6, 2015 04:36 AM
MamaBear2015
Jun 27, 2015 09:49 PM
Kyrian
Jun 26, 2015 11:48 AM
sysblack
May 13, 2015 08:55 PM
normaspirated
Apr 26, 2002 03:04 PM
