Cam gear
Cam gear
hey guys I have a 01 Civic Ex i got the basic stuff done to it intake, headers, exhaust......and recently I did my cam gear is AEM........right now I have it at 0 degrees people tell me to put it at +1 other people tell me put it at -4 can anubody give me a tip....
Re: Cam gear
Retarding your cam will give you top end as to where advancing it will give you bottom and mid range. I would not go too far either way with it. Maybe try going 2 degrees and see what happens. Let me know because I am about to put a camgear on my car.
Re: Cam gear
lmao that's the most stupidest thing somebody has posted.....i'm waisting my time with you guys, you guys are no help
Re: Cam gear
Alright ******... I have seen my car on a dyno.. watched the tuner pull timing out with a piggy back and watch the factory ecu put it right back in. The factory ecu can adjust up to like 20 degrees of timing. If you are putting in mechanical timing and its taking it out electronically, it does you absolutely no good. You have to be able to tune both before it will help at all. If the cam is advanced, and the electronics stay the same it works... you get more timing and the mixture detonates earlier than it did before. If you advance it mechanically and the computer advances the spark electronically, you are back to where you started. Don't give me that BS about not being helpful. I don't post **** that I blew out my ***. If I don't know what I'm talking about I keep my mouth shut.
Re: Cam gear
hey bro when you do your cam gear, get it tuned and tell them to set it at +1 and you will get performance you want....good luck
Re: Cam gear
You ask for help on how to adjust a cam gear.... then you shut down a guy trying to help you, and you then give advice to the guy who gave you advice... on what grounds!?? I dont get you man.
Re: Cam gear
nirvanaguy
25
Oct 26, 2017 07:26 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
tommycanada
Sep 5, 2015 04:59 PM
WaryDriver
Aug 16, 2015 11:22 AM
