difference between 7 and 8 gen civic suspension
Old Jan 24, 2009
Duf's Avatar
Duf
Duf is an unknown quantity at this point
Hi,
Just this little question,
is there a difference between a 04 civic coupe and a 2008 civic?
I'm meaning the suspension, can a 08 coilover kit be used on a 04 coupe?
Thanks,
Old Jan 26, 2009
Protan988's Avatar
Protan988 is an unknown quantity at this point
Re: difference between 7 and 8 gen civic suspension
I would search your the parts and see if both the same parts come up for both 8th gen and 7th gen. Otherwise probably no.
Old Jan 26, 2009
TRIZ's Avatar
I've only seen 8th gens on the road... havent looked up close at one at all. You are going to want to make sure the brake bolts up the same, and that the stud pattern on the top of the coilover is the same and the bolts are long enough to bolt onto the shock towers... Look at the tie rod mounting locations and size as well to see if it will fit- this steers your car... also the brake line mounting locations- you can probably fab up a bracked to hold the brake line pretty easily if they are different... but even if you look up part numbers they are going to be different but might still work. The only way to tell is if you get pics or look at the suspension first hand, which I havent.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
CapYoda
Nov 11, 2001 05:17 PM
fordfocussucks
Nov 8, 2001 11:03 AM
SleepyT
Nov 1, 2001 04:59 AM
