Car Vibrating HELP
Rep Power: 0 Car Vibrating HELP
hey guys i have a 2002 honda civic lx coupe
i just got new tires and a wheel alignment
when i got my alignment done ( from pepboys ) the guy told me that my front right strut was bent in and that this would cause uneven wear on my tire
now moving onto my question
once i take my car above 75mph it starts to vibrate, if im going under 75mph it is fine. Is this normal with all civics ?
if i were to change the front two struts would this stop the vibrating ?
or can there be something else wrong with my car ?
thanks
thanks
Rep Power: 0 Re: Car Vibrating HELP
I had a similar problem with my 2005.
I bought new tires, then I got a bad shake at like 58-62ish, then it would straiten out.
I took it somewhere else and tipped a guy 10 bucks and he re-balanced them and I got to watch, the first guy had it all messed up.
Now its smoothe at all speeds- no shakes- no vibes
i watched the guy balance the tires and the wheel alignment
but he told me that the passenger side strut is bent ( someone had backed up into my car ) and he told me that i should change both of the front struts
so what should i do ?? i am i dont want to spend like 400 dollars and find out its not the struts
When you say you watched the guy do the allignment and balancing what were you looking for? Sounds to me like you should pay the $20 to get her balanced again. I've brought my vic back to Honda after service to be rebalanced because of the same symptoms.
Also, there is a little mark (usually a circle- yellow or green or red paint) on the sidewall of the tire, this is a mark put on from the tire manufacturer to be lined-up with the valve stem. It's been my experience if the guy mounting the tires fails to do this, it makes them hard to get balanced correctly.....
Check your sidewalls? Did he line up the lil mark?
Well i too have a similar problem, now i had a crash a while ago were i bent all 4 alloys and snapped my anti roll bar... and bent the wishbone a bit.
Now i got the whole lot changed and i asked if there was any strut damage or offset camber but he said no it was ok.
Now could this just be bad wheel balance? or do you think there is something bent?
so how do i know if the tires will be balanced correctly ?
like what should i look for ?
BUT ... could it be the front passenger side strut ? my car only has 23k miles tho
Civicchicky87
Idle Issues
04-22-2015 07:16 PM
streetglower123
04-12-2015 10:56 AM
JjAnGPeETuL
11-08-2001 06:37 AM
